Old 02-21-2010, 10:37 PM   #1
rex01atv
Installed new lower ball joints/now truck sits 3/4 higher???
I just installed new lower ball joints (moog k6541) on my used djm drop lower arms, now my trucks sits 3/4'' higher in the front???? Why is this???
rex01atv is offline   Reply With Quote
Old 02-21-2010, 10:53 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Installed new lower ball joints/now truck sits 3/4 higher???
Maybe the spring is not seated in the upper spring pocket.
Keith
Convert to disc brakes.
Old 02-22-2010, 12:20 AM   #3
rex01atv
yea, I thought that to; so I took the spring back out and re installed with no luck? Could it be that the old ball joint was so old and deteriated that it was affecting the ride height?
Old 02-22-2010, 01:08 AM   #4
72hotrodder
THE TOY STORE
72hotrodder's Avatar
springs might need to just be worked down. i rebuilt my camaros suspentions over a weekend and it took it a few days to drop down back to were it was. or the old balljoints could have been that worn
having a badass truck and not driving it is like having a playboy model as a wife and not..... well you know.
72hotrodder is offline   Reply With Quote
Old 02-22-2010, 09:40 AM   #5
Shane
Shane's Avatar
sounds like the wrong ball joint ... not seating fully due to different taper ... the correct ball joint should have no affect on ride height.
Shane is offline   Reply With Quote
Old 02-22-2010, 12:27 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I agree with Shane, but let me throw in that my current dually had 1/2 inch of play in the worn ball joint. When I put new ball joints in, it regained the 1/2 inch. Any wear in the bj will cause the suspension to sag lower.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-22-2010, 10:05 PM   #7
rex01atv
Okay! That's what everybody elsae is telling me. My old ball joints were so bad I had to cut the castle nut off the threaded end because it was just spinning.
Old 02-23-2010, 07:11 PM   #8
cajundragger
I ran the part number and it seems you changed the bj in your late model chevy?
If so and you have dropped djm arms, you used the wrong bj. You need to go and grab some ford f150 bj's napa part number 260-1460 which is a napa gold, which I like better than moog.
cajundragger is offline   Reply With Quote
