Old 02-19-2010, 11:43 PM   #1
solidaxel
solidaxel's Avatar
53 chevy 3/4T Chassis
Can someone tell me the what the difference is in the lenght of a 3/4T Vs. the 1/2T frame?
I measured the front and rear width and the front is the same but the rear is 43" wide so not much taper at the rear. I want to place a 1/2T (53) bed on the long wheel base frame what problems am I going to have with the cab, core support, and the rear box?
I know I will need longer running boards and short aprons for the short bed.
CAn someone tell me what I am missing!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-20-2010, 12:09 AM   #2
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
Re: 53 chevy 3/4T Chassis
The overall length of a '53 1/2-ton is 191-1/4 inches with a wheelbase of 116.
3100 dimensions
The overall length of a '53 3/4-ton is 200-3/16 with a wheelbase of 124-1/4.
3600 dimensions
Are those the numbers you are looking for?
Steve@OldSub.com is offline   Reply With Quote
Old 02-22-2010, 11:56 PM   #3
solidaxel
solidaxel's Avatar
Thanks Steve, that helps alot.
It looks like everything will fit but the rear width of the frame, which brings up the spring mounts which are removed along with the rear end.
I will have to sleep on it some more
LS 3 4L70E
Old 02-23-2010, 12:29 AM   #4
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
3100 dimensions
3600 dimensions
I was just going to say 9 1/4", but that works to.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 02-23-2010, 12:37 AM   #5
solidaxel
solidaxel's Avatar
The section we added to the body is 10" I think we can cheat 3/4" in the rear mount and add a crossmember to the rear of the chassis to match the 1/2T bed rear crossmember
LS 3 4L70E
Old 02-23-2010, 12:39 AM   #6
nickp51chevy
Sounds like a good play to me
Had;
Old 02-23-2010, 07:30 AM   #7
Dan Bowles
AD Addict
I've got a 3/4 ton naked frame if there is anything you need "looked at."
I could mock up a box on it but you are right about the springs on the 3/4 ton being on the outside of the frame. It can't be that hard to put 1/2 ton springs under it or just use some "modern" springs from an S10 or 1500 truck. Those old springs are for a torque tube anyway so it might be better for lateral control to go with updated springs.
Dan Bowles is offline   Reply With Quote
Old 02-23-2010, 07:32 AM   #8
Dan Bowles
AD Addict
Just curious, how are you mounting your cab in the rear? Are you staying with the shackles or are you putting mount pads in like the front? Or is your cab old enough that it didn't have shackles to start with?
Old 02-23-2010, 11:31 AM   #9
solidaxel
solidaxel's Avatar
Thanks Dan,
Yes that is where we are at in the moch up stage.
I am trying to justify spending money on another frame (3/4) or using the
1/2T we have and add 10" to the middle under the cab.
The cab is a 53 so there are shackles on the rear.
Looking for all the challenges before we get any deeper in the build
LS 3 4L70E
Old 02-23-2010, 11:35 AM   #10
solidaxel
solidaxel's Avatar
I just went out and measured the width behind the cab and in front of the box and the 1/2T frame is 37 1/4". is the 3/4T the same at that location.
How does the 3/4T box mount at the rear to the frame?
LS 3 4L70E
Old 02-23-2010, 01:04 PM   #11
Steve@OldSub.com
Same as a 1/2-ton. A couple of ears on the cross sill with bolts through them into the frame.
Funny thing is just Sunday I looked at two '54 Chevy pickups, a 1/2-ton and then a 3/4-ton both with all the bed wood removed. Part of the purpose was to show a buddy exactly what is the same and what is different.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Old 02-23-2010, 05:26 PM   #12
Dan Bowles
AD Addict
I'm just wondering if you need to do any floor stiffening where the shackles are. Not sure how the weight distribution changes with your 10" addition. That's why I was thinking of a second set of "front" mounts for the rear or even what some of the S10 guys are using back there.
Old 02-24-2010, 11:22 AM   #13
solidaxel
solidaxel's Avatar
I had not entertained that thought "Yet" but thanks for thinking ahead,
We did talk about a strengthing rib under the splice on the floor but not about a additional body support. Thanks
What do the S-10 mounts look like?
LS 3 4L70E
Old 02-24-2010, 11:24 AM   #14
solidaxel
solidaxel's Avatar
The frame only being 43" at the rear than the rear cross sill must be different also, correct?
LS 3 4L70E
Old 02-24-2010, 01:57 PM   #15
Steve@OldSub.com
I hadn't thought about that, but yes the 1/2- and 3/4-ton cross sills would need to be different because of the difference in frame width.
I looked it up in the LMC Truck catalog online and they show two different parts for 1/2- and 3/4-ton.
Steve@OldSub.com
Old 02-24-2010, 02:51 PM   #16
xJoey Dubsx
xJoey Dubsx's Avatar
glad u asked, I needed these dimensions too! Just not yet, but down the road.
[CENTER][FONT="Arial Black"]-------------------- Joey Dubs --------------------
2000 Dakota - Bagged, Shaved, and more
2003 Ram - Fast, and perdy
1951 GMC Stepside - All apart, like a puzzle.
xJoey Dubsx is offline   Reply With Quote
