Closed Thread
Old 02-25-2010, 05:37 PM   #876
nlped
nlped's Avatar
Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
SweeT!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 02-26-2010, 12:18 AM   #877
mcbassin
Still Learning
mcbassin's Avatar
Looking like some good progress out west!
mcbassin is offline
Old 02-26-2010, 01:57 AM   #878
lownfast
Gettinlow & Goinfast
My local transmission shop got them for me. Be advised they are not national pipe taper thread. You can crack your transmission if you install NPT too tight. Transmission cooler line fittings on these newer transmissions are NPST national pipe straight thread. My fittings are to inverted flare so I can try to use my original cooler lines.
If you are going AN fittings they make an adapter to go from the factory quick disconnect to the AN Or they also make AN to NPST.
Fittings which are linked to in my swap thread!!
Where can i find the quick disconnect to AN fittings for the trans? Do you have a part # ? thanks
Protouring Texas built rides-
78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390
71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html
70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo-
85' C20 crew, 5.3/6L90/S475 turbo-
68' C10 5.3/4L60/Level 2 coil overs
Facebook- Protouringtexasdotcom
Instagram- @Protouringtexas
lownfast is offline
Old 02-26-2010, 03:20 AM   #879
Oldschool82
Balls to the wall!
Oldschool82's Avatar
Thought I'd come check out your ride since you were nice enough to check out my thread. all I can say is ...nice truck..looks like you have really spent a lot of time on it. maybe mine will get on up there with yours one day.
Oldschool82 is offline
Old 02-26-2010, 10:03 AM   #880
menace121978
menace121978's Avatar
thanks for all the great comments guys!
i need some help though... i went to napa yesterday in search of a 3/8 npt coolant sensor. all they have listed is the 1/2. i honestly think the 1/2" is too big because of the flange on the exhaust manifold and i dont want to use the adaptor. they did find a 3/8 sensor but the ohms at 220* is different than the stock one. i didnt get it because i want the gauges to be a direct replacement(autometer). what 3/8" sensor should i go with? any vehicle years or part #'s?
ive been just gathering supplies and had to order the extended floor pan from captkaos since the 1st one i got is too small. still waiting on the back ordered twist-tite high psi hose from summit and the trans x member. need to order a radiator( natural finish, inlet/outlet on pass. side, with e-fans and trans cooler) order the s&p headers, and send the harness out. $$'s going to start flying...
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline
Old 02-26-2010, 01:15 PM   #881
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
AIRTEX Part #1T1008, or Standard Motor Products #TS76T. 1979 - 1995. Which is OK since you will be running a 90-91 cluster anyhow.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline
Old 02-26-2010, 01:16 PM   #882
glock35ipsc
Oh wait, I just re-read and saw that you will be using Autometer gauges? Then use whatever sender comes with the gauges.
Bob
Old 02-26-2010, 01:24 PM   #883
menace121978
thanks Bob!!
"Dennis the Menace"
Old 02-26-2010, 09:16 PM   #884
menace121978
little progress today!! 1 big step was that i finally ordered the s&p headers!!! whoo hooo!! and i also talked to hannah at wait4me. Jesse should be calling me back soon on the final price since they have to add in a couple connectors for the 4l80 since the esky had the 65e. so i'll get that sent off monday!! 2 steps closer to hearing her run
the other thing i did today was start on my firewall. cleaned the black stuff off and welded a couple holes (my 1st ones) and started on the seam that runs through the middle all the way across. its not the purdyest thing but it will work and i can only get better. and i figure what ever i screw up the painter can fix... thats why he makes the big bucks!
"Dennis the Menace"
Old 02-26-2010, 09:18 PM   #885
menace121978
and thank you Gerald, Billy, and Bob for all your help over the phone today. nothing like autobody/welding classes over the phone!
"Dennis the Menace"
Old 02-26-2010, 09:29 PM   #886
glock35ipsc
Looking sweet! You gonna try and fire this beast up so soon as you have everything needed to make it run?
Bob
Old 02-26-2010, 09:32 PM   #887
menace121978
after the harness all i need(i think) is the radiator!! also a few odds and ends like new intake gaskets and knock sensor harness, just to ease my mind.
oh yea, i need to order my gauges so i can install the coolant sensor.
"Dennis the Menace"
Old 02-26-2010, 10:11 PM   #888
54Caddy
GM Addicted
54Caddy's Avatar
if you need help doing the welding im down man.. Ill do it whenever just let me know.. Ill help you shave the firewall if you want..
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline
Old 02-26-2010, 10:45 PM   #889
mcbassin
Still Learning
mcbassin's Avatar
Welds are looking good!
mcbassin is offline
Old 02-26-2010, 11:48 PM   #890
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Looks good Dennis. Like I said on the phone, and still think after looking at these pics, you could get away with a little longer welds. That should help you get better penetration and thus help you out. But again, looking good! Keep at it.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline
Old 02-27-2010, 12:55 AM   #891
draggin86
draggin86's Avatar
I agree the firewall is pretty stout not something that is going to warp like a door or bed side it has a lot of shape to it and doubled up seams
draggin86 is offline
Old 02-27-2010, 01:24 AM   #892
Driveway Dreams
I have car A.D.D.
Dennis, I sent you an email to try to show you what I was trying to say with the welds. I hope it helps you out a little more.
-Gerald
Old 02-27-2010, 09:10 AM   #893
JohnC
JohnC's Avatar
Looks good Dennis.
JohnC is offline
Old 02-27-2010, 10:25 PM   #894
fpjr0
fpjr0's Avatar
good progress!!!!
fpjr0 is offline
Old 02-27-2010, 10:40 PM   #895
menace121978
thanks guys! been slowly working on the fire wall and patiently waiting for parts. not much to show in pics. maybe 6 inches more of the seam welded and 4 more holes filled
"Dennis the Menace"
Old 02-28-2010, 01:32 AM   #896
Driveway Dreams
I have car A.D.D.
It's still progress.
-Gerald
Old 02-28-2010, 04:04 PM   #897
JohnC
JohnC's Avatar
That's right. Progress is progress!
JohnC is offline
Old 02-28-2010, 05:48 PM   #898
fpjr0
fpjr0's Avatar
I 2nd the progress is progress.... how ever right now I want to ask for a minute of silence due to the sudden death of my newly swapped 5.3/4l60e combo the transmission is fried after nearly 300 miles since the swap,, I went for a drive today and I nocited a hesitation when on the freeway... only to pull over and nocited a heavy smell of burnt transmission tried to take off again and all I have is 1 and 2nd gears and then slips into 3rd and comes in and out of 3rd.. a sad day.
fpjr0 is offline
Old 02-28-2010, 08:00 PM   #899
Driveway Dreams
I have car A.D.D.
Ouch. Sorry for your trouble. Hopefully it is just a repair for you. Not a loss of a dearly needed member of your family.
-Gerald
Old 02-28-2010, 08:44 PM   #900
menace121978
damn! thats a bummer man. i wish you the best on getting her fixed. but 1 positive thing though... you made me feel better about going with the 80e.
"Dennis the Menace"
Closed Thread
