Re: Bolt patterns for 65-75 chevy truck frames
Some guys love it, some not so much. I tried because my friends have used it w/very nice results (n2billet & Tx Firefighter both did their engines w/the stuff & they looked GREAT!).
I used it on my 350 block w/good results. I did some aluminum stuff that was going to top it off & it didn't work worth a crap. I wound up getting that stuff powder-coated.
Did you leave the metal rough before using it? Or did you clean and sand it down, I get mixed messages from other sites about how to prep the body before painting it with the stuff.
Cleaned & prepped. I do not believe the BS/hype about 'over-prepping' the substrate causing sealing or application issues. It worked for the iron engine block & heads & would prob do as well for the chassis stuff.
