![]() Join Date: Jan 2010
Biggest tires on a 4 in lift.
Hey im pretty new here, im sure there is a thread for it but just dont have the time to search around for it... But anyway i was wondering what size tires everyone is runing with there 4in lifts (no body lifts) I have a 85 shortbed with a 4in lift. Runinng 35x12.50r15 on stock chevy steelies.. well anyway anyone running anything bigger that 35s without a BL if so what wheels and off set and **** like that and how well do they clear... thanks for the help guys...
Hers my rig btw (rear springs are sagging ![]()
85 K10 shortbed- Camed SBC with 4in lift and 35's ![]() My name is Chevy, and my tank is empty.... ![]() Last edited by 85ShortBedSB; 02-25-2010 at 03:04 PM. |
Re: Biggest tires on a 4 in lift.
Welcome- You have a nice k10 their. Hmm I dodnt know if you can put a bigger tire on their without lifting it anymore. If you want more why not just lift it more? I got a 84 k10 with a 6'' lift and running 35's on it but, I want more height now. lol
Its Kool to be a square ![]() 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers ![]() ![]() --- ![]() ![]() ![]() |
hey thanks. yeah i should have gone with the 6in to begin with cause the lift is brand new. ive read that you can clear 37x13.50s with a 6in with no problem, but i cleared 35s before i even lifted it. just rubed the ouside fender when was turning hard enough to get some body roll. Even though i hate them. might be doing a body lift cause i want at least 37s
85 K10 shortbed- Camed SBC with 4in lift and 35's ![]() My name is Chevy, and my tank is empty.... ![]() |
Another Day, Another Dollar
i'm 4" up with 35's and i wouldnt dare putting bigger moccasins on there.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
Resident of Here
You can go bigger. But then you lose sheet metal.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
I don’t think you’re going to be getting much bigger than a 35.
However, I’d be interested to see if you can clear 37’s on a 6”...I love to run that combo on the Sub. |
I know for a fact about clearing 37's with a 6. you just gotta have the right offset wheels.
you can run 33/12.5 under a 4' kit on a 10wide wheel or 35/12.5 on a 8 or 8.5wide wheel, same goes for the 6' kit and 37's
Actually I completely clear my 37's on my 6" all spring lift. Wheels that i'm running are 17x9" "Ultra type 164" tires are 37x13.50r17 Toyo MT's, lift kit 6" Tuff Country. No blocks on rear axle.
i had 36s back in the day on a blazer.no problems at all.
but i soon threw a 6in lift after |
my dad has 37 on a 4 inch, but he had to cut the corner on the front fender ( half inch or so) so he could turn with out rubbing
Chevys Kick A$$
Yea I was gonna say always seen 4" lift and 35"s or 33"s unless you want to cut sheet metal off!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
My 84 had 6" lift and 35", they rubbed on lite wheeling. I had 10" rims, but can't remember what the b/s was. They didn't stick out too bad, but enough to make them rub.
If you run the stock rally's with 4" 35s will fit, but IMO 10" rim they won't without trimming.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
I had a 4" lift on 35/12.5/15 BFGs and stock wheels. looked great. downsized to 33's so I could actually take the truck to Hollister Hills. I wouldnt run bigger than a 35" tire on a stock half-ton rear end
#15 |
Okay thanks guys for the info. Im just gonnna stick with the 4 and 35s for now maybe just some wider wheels...
