Closed Thread
Old 02-26-2010, 01:32 AM   #901
SCOTI
SCOTI's Avatar
Re: What did you do to your truck today?
I cut some of my steel floor up & re-arranged the pieces to make room for a flush fill stainless fuel filler. I posted a cell phone pic in my build thread.
I also dropped/broke my camera .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now
Old 02-26-2010, 09:30 AM   #902
scooterskoolkustoms
scooterskoolkustoms's Avatar
watched my truck get burred under the snow AGAIN.I hate nj can't wait to move back to calif.Road trip comming up soon.
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline
Old 02-26-2010, 03:16 PM   #903
panelrodder81
Doin' it live!
panelrodder81's Avatar
Got my transmission and carrier shimmed to take care of a wicked vibration at highway speeds. Works great now... minus the uber low gearing in the axle that I need to replace.
-Panelrodder
1953 GMC Panel truck - 'Curly'
1961 Chevy Suburban - 'Larry' - Sold
2005 Harley Sportster - 'Shemp'
panelrodder81 is offline
Old 02-26-2010, 03:21 PM   #904
Twiztid_66c10
got brake master cylinder installed, licensed and insured and title put in my about to take tuck out of town first time since at least 93 thats what the old plates and tags say
1966 C-10 long wide- currently with 2 3/4 sectioned crossmember, 3 inch cupped a arms with 2700 bags, 67 master cylinder, in the middle of a v8 swap,
soon custom rear wishbone set up and bags
1942 chevy/divco ambulance
1937 chevy truck
Twiztid_66c10 is offline
Old 02-27-2010, 01:21 AM   #905
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
I pulled the motor and trans out so I can run my brake and fuel lines.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline
Old 02-27-2010, 02:09 AM   #906
Bugeyev8
Bugeyev8's Avatar
Got the 98-01 Dodge Ram seats installed in my 62...what a pain in the ASS !!
Bugeyev8 is offline
Old 02-28-2010, 01:21 AM   #907
Chevy Fleetside
Chevy Fleetside's Avatar
Stripped and cut up the 81 parts truck with a couple of friends/board members today. It is cut into managable pieces. I found out it has a 200R4 tranny and came with an aluminum drive shaft. The drive shaft must weight about 10 lbs. It was refered to being a pvc pipe. I am going to use it in the 66. I think the engine is a 5.0 so I guess that will go to the scrap yard.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 02-28-2010, 02:08 AM   #908
64c20crewcab
64c20crewcab's Avatar
With front sheet metal off and motor yanked within the last 7 days, I started the frame cleanup - removal of the oil sludge from frame rail, cross member n front suspension. Lots done but nowhere near finished.....
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline
Old 02-28-2010, 02:12 AM   #909
SCOTI
SCOTI's Avatar
Cut up the bed floor a little more. Welded it back together in a slightly different configuration. Grinding before, during, & after.
Build thread updated....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is online now
Old 02-28-2010, 02:25 AM   #910
Slow Build
Slow Build's Avatar
It was kinda fun watching team sawsall in action (team motto: We have extra blades and we're not afraid to use em). When it started raining I thought there was no way we would get it torn all the way down. But when it stopped raining you guys ( and gal) hit full stride. Good fun.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 02-28-2010, 09:17 AM   #911
thunder71
thunder71's Avatar
picked up another rusty bucket 66 short stepper saved from the crusher
thunder71 is offline
Old 02-28-2010, 12:12 PM   #912
64GMCHorsepower
Justified!
Fixed my brakelights, fixed my turn signals......Got my new alternator installeds, got my shocks installed....bumper installed...temporarily......Just gotta bolt down the passenger seat, tie up the wiring under the dash, install the radio and speakers, and we are ready tp drive!!!
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline
Old 02-28-2010, 05:20 PM   #913
carnuts07
carnuts07's Avatar
emptyied snow from bed and found a bunch of junk from the PO
carnuts07 is offline
Old 02-28-2010, 05:31 PM   #914
Sillyoldman
#16876
Sillyoldman's Avatar
I moved it under its own power. Needs pipes. No brakes yet. Was hoping to run brake lines this weekend but it just ain't happening. Plan is to get it running and stopping properly then Ill start cutting and welding in new rocker, floor & cab corners.
My cruddy video today. Music is Feel the noise, quiet riot. That was not planned
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline
Old 02-28-2010, 06:09 PM   #915
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
Broke my 61' down to the bare frame. Cut the floors out of it in prep for the floor replacement in my 66 Burb. Moved the 5 lug crossmember from the 61' to the burb. Did alot of cutting, grinding, getting dirty. Lots of progress, now to cut out the rusty burb floors!!
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline
Old 02-28-2010, 06:33 PM   #916
ravens65
ravens65's Avatar
Well.... finally got to work on it again. ran the rest of the new wiring harness (e-z wiring my a$$) don't buy from them!!! installed the billet gauge cluster with ultra-lite gauges and billet knobs and also installed my grille. all thats left for the wiring is the heater, stereo, electric seats and tail lights Hey anybody know how to wire the aftermarket tailights???? there is two wires in the lights a green and a black and the wiring harness has one for stop lights and one for running lights , thought that the black would be ground but...... is one wire for each and the ground is from bolting the housing to the fender???if so which wire?? after wiring the two spd wiper motor this should be a no-brainer for me but still confused. E-z wiring is crap had to buy $40.00 worth of connectors and $30.00 of wire . one wire for wipers, what a joke the wipers should have about 6 wires, had to keep getting online for diagrams also do I need that p.o.s. relay for the heater, it looks like a small electric heater ???? look at all the finger prints that I will always have!!! what was I thinking? can really smell all that leather in there,( leather dash, headliner, pillar post, door panels) it sure smells new. Eric
If it has tits or wheels its gonna give you problems!!!
ravens65 is offline
Old 02-28-2010, 10:32 PM   #917
lock
Insert funny comment.
lock's Avatar
Finished powdercoating my front brake components and mocked them up.
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline
Old 02-28-2010, 11:26 PM   #918
nbrfd007
nbrfd007's Avatar
It's Alive, my 62 Burb, put a new carb on today. Started on first try. Sounds great, got the clutch working. Drove it for the first time. Still got to work on the brakes.
nbrfd007 is offline
Old 03-01-2010, 12:28 AM   #919
ruffrida2005
Glad to see you back to work on it Eric.
I went to my parents house to load up my 64 cab. comes to find out the roof skin is cracked pretty much all the way around the drip rail. Windshield metal needs fixed. Too much work for the cab. I'm going to break out some dynoglass on it all so I can drive the truck till I can afford a new cab. I think a new one will be cheaper.
Paul
Old 03-01-2010, 12:17 PM   #920
Mitch6667
Finished the tubular trailing arms (now i just need to triangulate them). Replaced pan hard bar crossmember, and transmission crossmember with a tubular style. Also ordered coil overs for the rear. Has we say on the eastern shore, It has been an Oh **** Son day.
Mitch6667 is offline
Old 03-01-2010, 12:59 PM   #921
panelrodder81
Doin' it live!
Did an oil change to get a better idea of the condition of the engine I just put in and have been driving for about a month. Oil was really solid, wasn't abnormally black, nor did it have any grit in it... yay. Fixed an oil leak on the top of the motor, who would have thought you'd need a gasket under the distributor! (I forgot to put it on when I put the HEI in I guess.) Then I installed a cheap little oil gauge in the truck since all I have are idiot lights. Ran out of time to make my gauge holder/bracket so it's just zip-tied to the dash for now. Next weekend I'll finish that up and get my temp gauge installed and put my new torque converter cover on... hopefully.
-Panelrodder
Old 03-01-2010, 07:17 PM   #922
Vernski
Eric nice looking truck I like the gauges they look good. Did you powder-coat the grill & bumper or paint it? They have that soft look....Vernski
Vernski is offline
Old 03-01-2010, 07:54 PM   #923
64c20crewcab
2/28/10 Lots accomplished on the frame clean up from forward cab mount to front bumper mount. Not done but getting there! Time, patients and favorable weather helped!
Y2K INDN Chief
Old 03-01-2010, 08:27 PM   #924
lakeroadster
Got the gauges mounted in the '67 Camaro dash in my '65 SWB SS. Also installed boots for the Shifter and floor hand brake.
lakeroadster is offline
Old 03-01-2010, 10:44 PM   #925
Turkey
Turkey's Avatar
Used the hood for a table so I could pinstripe my helmet.
Turkey is offline
Closed Thread
