Old 02-28-2010, 01:18 AM   #1
bigblocksean
67 C/10 BBC mounts
Greetings all, I have a question on placement of a BBC into the 67 C/10 the frame mounts were for a sbc, does the bbc need to be set back farther, thank you
bigblocksean is offline   Reply With Quote
Old 02-28-2010, 01:48 AM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: 67 C/10 BBC mounts
You will probably want to use a set of big block towers in the front set of holes in the frame. I am not positive on the 67 frame being the same as later as far as location, but i am pretty sure...
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-28-2010, 02:18 AM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I'm no expert on this but I recall that the hole placement is right (front set). but the frame is too narrow, so you need to grind about 1/4" off each side to make them fit. I'm sure someone has more expertise though.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 02-28-2010, 07:11 PM   #4
bigblocksean
Thanks guys! wow those factory big block mounts are spendy, problem solved I fabbed up a set that is going to work great.
