Old 02-28-2010, 10:55 PM   #1451
daverod
SSN 706
daverod's Avatar
Re: Daverods project 66
It runs I'm thinking at first I had the dist. in right but it was one tooth off. I had it running but not very good. I thought it was my plugs so I changed my plug gaps back to what they were orginally. It was still backfiring so I pulled the dist. and turned it 180. When I did that I put my wires back on counterclockwise., thats when the real trouble begain. Dumb a$$. Here I thought I was being smart by taking a picture of everything before I began the swap. I must have check the order 20 times 153624. Oh well, learned some stuff and its running. Tomorrow I weld up the exhaust and go burning around. I did'nt really want to go sledding today anyway. I was still sore from my wipeout last weekend.
daverod is offline   Reply With Quote
Old 03-01-2010, 11:02 AM   #1452
chemlab
chemlab's Avatar
you could always do the thumb on the #1 plug hole trick for a quick check, wherever the distributor head is sitting at will be your #1, and redo your wiring from there. i've done this countless times and works fine.
chemlab is offline   Reply With Quote
Old 03-01-2010, 11:51 AM   #1453
daverod
SSN 706
daverod's Avatar
When you do it that way how do you know if it's on the compression or exhaust stroke. Does it only blow air on the compression stroke? It seems that your dist. could still be 180 off?
Old 03-01-2010, 03:26 PM   #1454
daverod
SSN 706
daverod's Avatar
Got my exhaust welded up. Lots easier to weld nice clean new metal together. Need to go buy some tips
Old 03-01-2010, 03:31 PM   #1455
MacAttack
283 Drama Queen
MacAttack's Avatar
Made the identical mistake on my '283': Confused exhaust stroke with compression - until I used a compression gauge on #1.
Piece-of-cake after that and the little motor fired right off.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 03-01-2010, 03:35 PM   #1456
daverod
SSN 706
daverod's Avatar
Does it still blow air out the hole on the exhaust stroke?
Old 03-01-2010, 03:40 PM   #1457
MacAttack
283 Drama Queen
MacAttack's Avatar
Yes - just not at the velocity of the compression.
Old 03-01-2010, 03:42 PM   #1458
daverod
SSN 706
daverod's Avatar
Thats what I thought. Just was'nt sure.
Old 03-01-2010, 03:44 PM   #1459
MacAttack
283 Drama Queen
MacAttack's Avatar
Yeah - I almost took my valve cover off to confirm both valves were closed, but after getting them sealed just the way I wanted - I didn't want to mess with it and went with the compression gauge, while looking at the harmonic balancer marks.
Old 03-01-2010, 03:46 PM   #1460
daverod
SSN 706
daverod's Avatar
I ended up taking my cover off. Could'nt figure out what the hell was going on.
Old 03-01-2010, 03:53 PM   #1461
MacAttack
283 Drama Queen
MacAttack's Avatar
You'll get it now - it can't hide for long!
Old 03-01-2010, 03:56 PM   #1462
MacAttack
283 Drama Queen
MacAttack's Avatar
BTW - That exhaust system is da chit!
Old 03-01-2010, 04:01 PM   #1463
daverod
SSN 706
daverod's Avatar
Can't wait to go for a drive. New HEI and new X pipe and tail pipes. I won't need ear plugs now. I was driving with just the bombs it was loud.
Old 03-01-2010, 06:13 PM   #1464
kizer
Its Deja Vu time again
kizer's Avatar
Woooohoooo it only took me 58.5 pages to catch up.
Whats up with this. I leave and your working on one rig and I come back and your working on another.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 03-01-2010, 07:12 PM   #1465
daverod
SSN 706
daverod's Avatar
And now I'm looking for a 47-53. Found a few but they were mostly rust. Damn, page three, you did have some catching up to do. Where you in a induced coma? Glad to see you back.
Old 03-01-2010, 07:44 PM   #1466
chemlab
chemlab's Avatar
yes, air is released on the compression stroke.
Old 03-01-2010, 08:54 PM   #1467
daverod
SSN 706
daverod's Avatar
Just because air comes out the hole you don't know if it on the compression or exhaust stroke. You could put your dizzy in and it could 180 out. I like the compression gage idea, keeps you from taking the valve cover off to see what stroke your really on.
Old 03-01-2010, 08:58 PM   #1468
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
shouldnt there be alot more pressure on the compression stroke
enough that you can tell
ive always gotten it right
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 03-01-2010, 09:04 PM   #1469
daverod
SSN 706
daverod's Avatar
I was just turning it over using the fan. That was'nt my problem anyway. I think I was a tooth off.
Old 03-01-2010, 10:44 PM   #1470
Strodder
Daring to be Different
Strodder's Avatar
A good way to tell is remove the valve cover, and rock the engine at the timing mark. Look at #1 rockers, if intake and exhaust are rocking also that's #1. That is if I remember that right....
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 03-04-2010, 09:22 PM   #1471
daverod
SSN 706
daverod's Avatar
Put my rubber door seals on and got my mat in. Don't know what I'm going to do about the peal and seal? Thing runs super. Sounds great, not to loud untill you get on. So much for the paint on the headers. I have my timing set at 4?
Old 03-04-2010, 11:58 PM   #1472
Strodder
Strodder's Avatar
Looks good Dave
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-05-2010, 12:08 AM   #1473
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I want a daily driver.
Alan's Classic is offline   Reply With Quote
Old 03-05-2010, 12:41 AM   #1474
daverod
SSN 706
daverod's Avatar
Get that 55 running and there you go.
Old 03-05-2010, 12:42 AM   #1475
Alan's Classic
It's getting there.
