Old 02-25-2010, 10:28 AM   #2326
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Project Vitamin C-10
Originally Posted by jason65 View Post
Looks good Alan.
Thanks Jason
Originally Posted by LinkbeltOE View Post
Alan,
What radiator did you use and where did you get it from? Also how much?
Summit PN SUM-381328 $211.95
Alan's Classic is offline   Reply With Quote
Old 02-25-2010, 12:20 PM   #2327
62gmc910
62gmc910's Avatar
looking good , on the brake fitting , it is for a trailer brake controler , if you look it says tekonsha on it so your right in taking it out,
The 45 degree flares should seal up ok as long as the nuts engage enough thread. and again some very nice workmanship!!!
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 02-25-2010, 12:41 PM   #2328
Alan's Classic
Thanks for the info and comments. That clears up the mistery.
Another intersting site for hardware and fasteners. Allensfateners.com I was searching for adel clamps and stumbled across the site. Looks promising.
Old 02-25-2010, 12:57 PM   #2329
Strodder
Daring to be Different
Strodder's Avatar
Man you did some crazy bends. Looks great.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 02-27-2010, 09:14 PM   #2330
Alan's Classic
I wish I could take credit for it. They are bought.
Getting ready to build the brakes in the rear.
The mod I did to the crossmember to make it work with 72 brake lines worked out perfect.
Shannon is bringing a bracket over tonight to mount the T on the rearend. Also talked to the Truck Shop and they will send out another front prop valve line to frame to replace the lumpy one.
Old 02-27-2010, 09:40 PM   #2331
my67chevytruck
Under Construction
my67chevytruck's Avatar
Great mod on the rear, i did the same but didnt think about it until after it was painted
so i cut and bolted the bracket on. Looking good alan!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-28-2010, 10:25 AM   #2332
Alan's Classic
Shannon brought the bracket over and it worked perfectly. Got the wheel cylinders in and the rear brake lines buttoned up.
Old 02-28-2010, 12:14 PM   #2333
protrash64
Resistance is Futile
protrash64's Avatar
Lookin' good Alan!!!! Gettin' closer every time I check in to see whats up. Keep it going; you're almost there.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-28-2010, 03:46 PM   #2334
Strodder
Strodder's Avatar
[QUOTE=Alan's Classic;3829679]I wish I could take credit for it. They are bought.
That's what I like about you Allan. Being honest. If you try hard you can probably do it. But would it worth it?
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 02-28-2010, 04:03 PM   #2335
jason65
Registerd User
jason65's Avatar
Looking good as usual Alan.
jason65 is offline   Reply With Quote
Old 03-01-2010, 02:15 PM   #2336
kizer
Its Deja Vu time again
kizer's Avatar
I haven't been around lately for one reason or another, but like usual Alan top notch work my friend.
I hope your not saving receipts for everything you buy because I bet it will scare you in the end.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 03-01-2010, 11:55 PM   #2337
4dranch
Shloooooong bed member #2
4dranch's Avatar
Alan,
very..very..nice. and real clean work on the lines.
Did you ever find that fitting you were hunting or decide on something else?
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 03-02-2010, 12:49 AM   #2338
Alan's Classic
Thanks, one thing at a time is progress.
Thanks, I have no reason to lie about my limitations. Yes, I will be better with practice. But right now the cost would be enormous if I tried to do all my brake lines right now.
Thanks Jason!!
Glad to seee you around here again. I quit adding receipts last year. It was close to 10K not counting labor.
Originally Posted by 4dranch View Post
Alan,
Thanks David, I went with a different fuel pump. That fixed the problem.
Shannon came over to supervise me on my 3rd attempt on the fuel line. Bending tubing is getting a little easier, but I've got a lot to learn. Practice, practice, practice.
Yours truely.
The line is done.
Old 03-02-2010, 02:19 AM   #2339
SCOTI
SCOTI's Avatar
Nice progress. The rear lines look like a quality fit.... what manufacturer?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-02-2010, 03:46 PM   #2340
Alan's Classic
I ordered them from truckandcarshop.com. Each line comes tagged so you have a clue to where it goes.
Got my fuel tank from ??????? today. A couple issues that I PM'd him about. Overall pleased so far. A couple issues were my fault for assuming.
The correct wheel tubs came today.
Radiator saddles and upper clamps came in today.
Old 03-02-2010, 04:54 PM   #2341
MacAttack
283 Drama Queen
MacAttack's Avatar
Oh wow - that juice tank and coolant assembly are outrageous!
Not quite stock - eh, Alan?
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 03-02-2010, 05:34 PM   #2342
Strodder
Strodder's Avatar
Yeah they look GREAT
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-02-2010, 07:52 PM   #2343
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
coming along nice Alan.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 03-02-2010, 09:46 PM   #2344
jsmithbm
jsmithbm's Avatar
[QUOTE=Alan's Classic;3816433]Thanks Joel. Any time I learn something that looks easy usually proves me wrong. You gonna post any pics of your progress?
Okay Alan, go see em! i even painted a part
Learning as I go!
jsmithbm is offline   Reply With Quote
Old 03-02-2010, 11:22 PM   #2345
Alan's Classic
I think I crossed the stock line a little while ago.
Thanks Dennis and Paul
I'll go check them out.
The wheel tubs seam to fit pretty good. No complaints.
I don't have much room to play when I fab up the fan shroud.
Old 03-02-2010, 11:47 PM   #2346
daverod
SSN 706
daverod's Avatar
Your getting close to taking that thing for a drive. Looks good.
daverod is offline   Reply With Quote
Old 03-03-2010, 12:11 AM   #2347
ruffrida2005
You going to leave those high speed fan straps?
Paul
Old 03-03-2010, 12:39 AM   #2348
198plus
198plus's Avatar
Those are sweet..........
198plus is offline   Reply With Quote
Old 03-03-2010, 12:40 AM   #2349
198plus
198plus's Avatar
Great job on everything as usual Alan
Old 03-03-2010, 11:31 AM   #2350
MacAttack
283 Drama Queen
MacAttack's Avatar
The tubs look sweet - and the power steering plumbing is primo!
This build's got to be made into an illustrated catalog - I'd pay $50 for it in a heart-beat. Best work I've ever seen, or even heard about.
Mac.
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
