Gmc 702 c.i. V12
Thats right a GMC V12. Check out this link, they are bringing them back, not sure if they will fit in our trucks, but I bet some of you guys can make it fit.
http://www.thunderv12.com/
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
I know the pieces fit
Re: Gmc 702 c.i. V12
2400 rpm peak power with the stock cam, closer to 3000 rpm peak power with their "HP" cam. Cool novelty item though.
Another Day, Another Dollar
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Pretty cool looking. I'll stick to my 6.0 though. LS POWAAA
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
1977 GMC Sierra Grande |
This is actually on my "to do" list.
The way i would do it would be to move the cab back and shorten the bed; It actually looks pretty good in my mind and if i get around to it i'll make up a sketch and post it. |
BAD BOW-Silverado XST
Fact: GM is now selling the latest in engineering technology, the LS9 supercharged V8 crate engine. It is a marvel. Yet with all the advancements and the addition of a supercharger, the advertised torque of 604lb-ft has not caught the 630 lb-ft that GMC advertised in 1960 for the stock 702 V12! And in our opinion, the looks of the V12 is still un-matchable. We have seen the LS9 for sale at $4,000 more than a ThunderV12. Wow! We are sure the LS9 is also a good looking engine, but until someone removes all the beauty covers and other "stuff" so we can see the actual motor, we won't know for sure.
It looks like two v-6's bolted together in the middle
they look pretty beasty, but from some of the pictures posted, it looks like two 350 together, explains the around 700 ci
high-Tech Red Neck
Man one of those would be way cool in a mohagany boat.
"He used to be a pretty nice feller, now he's a welder!" |
high-Tech Red Neck
Like the one in this video
Now if you had a matching 60's chevy 3/4 ton to pull said boat, that would be even cooler.
Ironmonger
![]() Join Date: Dec 2004
It is two GMC V6s put together. One block, crank, cam, etc. but V6 heads, rods, etc.
Those V12s were probably the best-SOUNDING truck engine ever built. I almost deluded myself into picking up an old Packard frame off eBay to build into a rod with one of these things in it, but common sense intervened. I did some sketches and dimensions for an underslung frame for a Brooklands-style track roadster (google Napier-Railton) that'd be just about right for a 702, but that's going to wait until I find a first-rate aluminum panel beater who works for beer money (fat chance, that.) Last edited by JEM; 03-02-2010 at 12:43 AM. |
#13 | |
78 C-10 5.3 LSX -4L60E |
It'd be alot cooler if you did
A sure sign they aren't doing so well financially:
Reserve an engine for 2010 production for 25% down. Reserve an engine for 2011 production for 10% down. |
#15 |
here is one in a bad a$$ hot rod COE
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#16 |
Next project: 1970 K10
There use to be a few of those in the Wellington area that were used to power irrigating water pumps, and they ran 24/7. There were also some pumps that ran Hemis.... both 348's and 426's.
I would LOVE to build a hot rod around one of those engines!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 03-02-2010 at 01:59 PM. |
#17 |
#18 | |
I believe he is a member here and has a build thread for that.
I think his screen name is coyoterun? *EDIT - yes it is here as posted by pyrotechnic above Quote:
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 03-03-2010 at 02:14 AM. |
