03-02-2010, 04:56 PM | #1 |
Formerly- 1972SuperCheyenne
NEED: PS pump fitting
Anyone have an old (possibly bad) power steering pump laying around? I need the fitting that screws into the back that the pressure line screws into. LMK, thanks.
EDIT: I dont know if they changed from standard to metric or vice versa throughout the years but I need one that'll fit a 1986
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. Last edited by STOCKISH; 03-02-2010 at 05:00 PM. |
03-03-2010, 02:40 AM | #2 |
Re: NEED: PS pump fitting
If that part is not different from 2 to 4wd you can have the one off my K5. I have to swap to the 2wd stuff anyways and I'll just run the pump that is still attached to that steering box.
edit: its an 87
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 03-03-2010 at 02:40 AM. |
03-03-2010, 08:54 AM | #3 |
Thanks. PM sent
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
