03-02-2010, 11:05 PM | #1 |
Frame Question
This may sound like a stupid question, but what the heck!
Is the frame, (SWB or LWB), on a 67-72 10 series truck the same as the frame on a 20 series? i.e. physical size & strength? (not counting brakes and suspension), just the frame. Curious... Thanks |
03-03-2010, 12:41 AM | #2 |
20' Daredevil (Ret)
Re: Frame Question
Not a stupid question at all.... it's been asked a few times here. They are the same -- the one-tons (30-series) have a larger frame (deeper, I believe), but the 10 and 20 series are the same.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
03-03-2010, 09:56 AM | #3 |
Junior Member
Re: Frame Question
The differences I have found on my '67 C-20 frame and my '71 C-10 frame are the '67 does not have the dimple for the steering box and the C-20 frame has extra braces at the cross memeber where the trailing arms mount.
The trailing arms on the C-20 are a little beefier with a plate on them and the rear cab mounts are lower on the frame. If I remember right someone on here said the '71 and '72 frames were made out of higher strength steel. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
03-03-2010, 12:59 PM | #4 |
Watch out for your cornhole !
Re: Frame Question
03-03-2010, 01:08 PM | #5 |
20' Daredevil (Ret)
Re: Frame Question
Well.... sorry about my bad advice. I coulda sworn I saw at least a few similar threads in the past where it was stated that 1/2T and 3/4T frames were the same, with 1-tons being stouter.
03-03-2010, 01:13 PM | #6 |
Re: Frame Question
Outside of the reinforced spots that TX Firefighter pointed out they are pretty well the same.
I've seen several 3/4 ton trucks converted to 1/2 ton with suspension and axle swaps. |
03-03-2010, 05:04 PM | #7 |
its all about the +6 inches
Re: Frame Question
the 3/4 ton is slightly thicker metal, have the braces as mentioned, have lower rear cab mounts (require 3/4 ton cab mounts regardless of what mods you've done suspentionwise).
The one tons are a thicker and taller C channel. 71/72 is in fact made of slighty stronger metal |
