wheel fitment
Greetings all, after finishing my frame and drivetrain on my 67 SWB. Iam ready to choose my wheels and tires, I like the 18" front 20" rear combos, question is what size fits and looks good. I have not yet lowered the truck, wanted to nail down the wheel and tire issue first. If anyone has any pics of this combo and there suspension info, It would be appreciated. I like the torque thrust M series with the silver centers, polished lip. The truck is being painted to its original color of Siera Fawn, I think it would look sweet. many thanks!
Re: wheel fitment
google TIRE SIZE CALCULATOR scroll down to wheelmasters and click might help
gives tire size and wheel info if it will clear |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: wheel fitment
Tell us what you have.
Still 6-lug drums on all 4 corners? Switching to 5-lug? Drops spindles require converting to disc brakes. I usually recommend doing the suspension first,... and then buying wheels.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-02-2010 at 03:08 PM. |
Re: wheel fitment
What lolife99 said. do the suspension first. After you see how much lower it sits you can choose the right size tire for it.
Re: wheel fitment
Thanks guys! Iam using a 71 frame so going to be utilizing the front disk rear drum 5 lug. Right now I have a gmpp 502 BBC and turbo 400. On the aftermarket drop springs when they say they lower the front 2 inches, is that rating any different when installing a big block? I just didnt want to order the wrong springs. thanks
Re: wheel fitment
I think ECE sells small block and big block specific springs.
I'm not sure about anyone else. How low are you going? 3/4, 4/6, 5/7 drop?
Re: wheel fitment
Thanks for the reply Lolife99, I was considering around a 3/4 drop. at what point would you consider c notching the rear?
#8 | |
Re: wheel fitment
My '69 swb has a 5.5"/7.5" drop. The rear is a littlle lower now,... than in this pic. This pic was taken after I finished lowering it, and before I had driven it much.
Forever Grateful
Re: wheel fitment
with a 5.5 inch drop in the front did you have to do anything to the front suspension(tubular arms etc....)
R.I.P Dad 04-07-42 - 05-27-09 |
#10 | |
Re: wheel fitment
Just 2.5" drop spindles and 3" drop springs. I trimmed the lower a-arms around the balljoint area and remove the bumpstop stand. That's it.
Forever Grateful
Re: wheel fitment
thanks...lolife
Re: wheel fitment
Thanks....lolife, that looks sweet!
Re: wheel fitment
hey lolife, where did you find the 6 lug center capsthat are on your '69?
Re: wheel fitment
They are off of the 88-98 4x4 trucks with steel wheels.
