Old 03-03-2010, 07:51 PM   #1
dadsgreentruck
dadsgreentruck's Avatar
Distributor wiring
I recently gutted my old points distributor and installed an electronic conversion. The coil I have requires a balast resistor. I got key on power for the module from the yellow wire that was going to the + side of the coil and I installed a balast resistor to the coil. Everything seems to work properly, but... from a cold start (first start of the day)... it takes three starts to stay running. I have since discovered that there is a resistance wire in the circuit that the yellow wire feeds from. Would I get better results from running a separate key on 12v line to the distributor module and eliminating the redundant balast?
1970 C10 LWB with SB 307 & TH350
dadsgreentruck is offline   Reply With Quote
Old 03-03-2010, 07:56 PM   #2
JimKshortstep4x4
Re: Distributor wiring
I would just elimminate the ballast resistor and use the existing resistor wire that is already in the harness.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-03-2010, 08:24 PM   #3
dadsgreentruck
Do you think there's any harm in powering the distributor from the resistance wire?
Old 03-03-2010, 08:37 PM   #4
fixit-p
fixit-p's Avatar
Thats what its intended for, I installed the Crane XR-I conversion in my 69 with the stock resistor wire.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 03-03-2010, 08:58 PM   #5
joeelutz
joeelutz's Avatar
According to Pertronix tech guys, you can power the module off of either straight 12V before the resistor or after the resistor (or resistor wire), but if you accidentally leave the switch on, the resistor can sometimes save the module from meltdown if you have it wired after the resistor. This happend to me on my 68 Camaro the night before I got married. I had the module wired in without the resistor wire and left the switch on the night before. The day of my wedding, my dad and I were in tuxes working on the distributor. Fun stuff.
joeelutz is offline   Reply With Quote
Old 03-03-2010, 10:07 PM   #6
powell72
powell72's Avatar
I installed the Pertronix kit and I ended up buying their Flame Thrower coil ($36). You can wire their coil straight to a 12V keyed source, no resistor, no BS. Then you can open up your plug gap to that of an HEI for a better burn.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 03-03-2010, 11:44 PM   #7
joeelutz
joeelutz's Avatar
I've had very bad luck with Flame thrower coils. They usually start to leak and then break down when hot.
Old 03-03-2010, 11:45 PM   #8
powell72
powell72's Avatar
Not what I wanted to hear!
Chris
