03-04-2010, 06:49 PM | #26 |
Re: Cutting front coil springs 72 1/2 Ton
I've lowered more of these trucks for guys in my town than I got fingers and toes.
Take a porterban saw and cut 1/2 round off bottome of spring and that will get you a 1" drop in front. Cut 1 complete round and your looking at 2" drop. Sounds like you got it covered to me.......... Best of luck!
Things happen for a reason! |
03-04-2010, 11:08 PM | #27 | |
These are a few pictures of the lowest I got it with around 2 1/2" Clearance to the ground |
03-04-2010, 11:23 PM | #28 |
67-72 Addict!
Used a cutoff tool and removed 90% of one coil and got close between 2-2.5" drop. Here's a before pic of my truck with just the 2.5" drop spindles and than an after pic showing the extra drop from cutting the coils.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
