Old 03-04-2010, 04:39 PM   #1
bigdon-70blazer
Tailgate trim center piece barrel clips
Does anyone know where I can get these new to clip on the center piece directly over the tailgate handle? LMC sells the entire part with the clips with it but I only need new clips.
bigdon-70blazer is offline   Reply With Quote
Old 03-04-2010, 05:20 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Tailgate trim center piece barrel clips
Don, try a home depot or Lowes. They carry a lot of random clips in their nuts and bolts section. Most will be in slide out cabinets. It's worth a shot. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 03-04-2010, 06:43 PM   #3
tires2burn
tires2burn's Avatar
Try this place Don. http://www.clipsandfasteners.com/
tires2burn is offline   Reply With Quote
Old 03-04-2010, 06:46 PM   #4
mbgmike
What do you need. We sell every barrel clip and moulding clip made. we can give you some for free.
mbgmike is offline   Reply With Quote
Old 03-04-2010, 08:39 PM   #5
bigdon-70blazer
The clips hold in the top middle section of tailgate trim by clamping onto each of the small studs on the trim part then pushed into hole on tailgate and clips into place. I have a couple of pics, the small clip is hard to see but you will be able to see where it goes and may have a trim part like this at your place. Free would be great but I am willing to pay if you have them, thanks for your generosity!
Old 03-04-2010, 09:51 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I got mine @ my local NAPA store.
LockDoc
Leon
Old 03-04-2010, 10:15 PM   #7
tcb-1
Nothing to see here.....
tcb-1's Avatar
I believe I have a source here in KC. if you can't find something with the above posts, text me.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-05-2010, 02:10 PM   #8
pickupman
pickupman's Avatar
I have them in stock, but you should be able to pick them up locally
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 03-05-2010, 04:26 PM   #9
bigdon-70blazer
Guys, thanks for the help but I found some at my local NAPA store! Thanks!
Old 03-05-2010, 04:44 PM   #10
mbgmike
Thier you go. Just remember us when needing small stuff. We sell everything seperate no matter what (or at least most stuff.) We are not like most stores we will sell a single part,bolt,bracket etc. Who does that?
