Old 03-04-2010, 11:12 PM   #1
texastrendz
brake lines with drop member
anyone have any pictures of the brake line setup they used with the drop member. i ordered one from nate this week, mine will be a little diffrent from the 3.2, but still would like to see some pics, thanks.
texastrendz is offline   Reply With Quote
Old 03-05-2010, 11:28 AM   #2
67cheby
67cheby
67cheby's Avatar
Re: brake lines with drop member
x2 i would like to see what you did also, i am assuming it will be all custom bent
67cheby is offline   Reply With Quote
Old 03-05-2010, 12:44 PM   #3
jlaird
jlaird's Avatar
here's mine. You will see clamps for two lines where one is empty. That will be for the air line.
The brake lines are 3/16" stainless. They are terminated to a -3AN fitting to connect a braided stainless line to the caliper.
jlaird is offline   Reply With Quote
Old 03-05-2010, 01:02 PM   #4
67cheby
67cheby
67cheby's Avatar
man that is clean, i will be cheating off of you , thank you
Old 03-05-2010, 01:47 PM   #5
nastyc10
nastyc10's Avatar
nice job jlaird! Where did u get those clamps from?
nastyc10 is offline   Reply With Quote
Old 03-05-2010, 02:16 PM   #6
jlaird
jlaird's Avatar
http://www.made4uproducts.com/
Old 03-05-2010, 02:49 PM   #7
Wild83C10
Wild83C10's Avatar
Definitely some nice work.
I am using Russell line clamps. Link
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-05-2010, 03:06 PM   #8
mike14_07
mike14_07's Avatar
nate told me to use 73-80 model front lines but after seeing those, i may do that. i looks sick
mike14_07 is offline   Reply With Quote
Old 03-05-2010, 07:09 PM   #9
jlaird
jlaird's Avatar
here are pics with the airlines installed. They are .25" stainless.
Old 03-05-2010, 07:15 PM   #10
68 short step
i think i see some dust on there .....very nice, just wondering if you flare the SS with a hydrolic 37* flare tool or a manual one. if its hydrolic where did you get it from...again very clean and nice
68 short step is offline   Reply With Quote
Old 03-05-2010, 07:57 PM   #11
jlaird
jlaird's Avatar
The brake lines are 45 degree double flares with a manual tool. The hydraulic would be nice though! but pricey. The airlines are flareless Swagelok fittings.
Old 03-05-2010, 08:00 PM   #12
bruce bruce
Nice work!
bruce bruce is offline   Reply With Quote
Old 03-05-2010, 08:28 PM   #13
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
what exact bender and flaring too are you using? I ended up buying a very nice (and VERY $$$) 37* for my air lines but now I still have to get one to do the brake lines.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-05-2010, 10:19 PM   #14
jlaird
jlaird's Avatar
Well the flaring tool I have I would not buy again. Its a great tool for steel, but a little wimpy when it comes to doing the stainless. It does it but you have to really show it who's boss!. Its a Snap-On/Blue Point flaring tool. If I were to buy another, I would look not further than Ridgid. I have a Ridged 37 degree flaring tool and that thing kicks 99.9% of the other brands butt. All my benders are also Ridgid. I will take picture for you guys in a second. Hold on...
Old 03-05-2010, 10:54 PM   #15
jlaird
jlaird's Avatar
Old 03-05-2010, 11:45 PM   #16
texastrendz
are you supposed to double flare stainless?
Old 03-06-2010, 01:58 AM   #17
PBFAB.COM
PBFAB.COM's Avatar
Beautiful work! I will definitely be hitting you up for a possible tech. write up on the brake line install with pics and part numbers to put on my site. Awesome!!!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-06-2010, 08:44 AM   #18
jlaird
jlaird's Avatar
YES. If you order straight lengths of stainless line from company's like Inline Tube, it comes double flared.
Not being able to double flare stainless is a common misconception.
Old 03-06-2010, 08:45 AM   #19
jlaird
jlaird's Avatar
No problem, just let me know.
Old 03-06-2010, 10:26 AM   #20
lolife99
67-72 parts collector,…
lolife99's Avatar
Wow. You make it look easy!
I know for a fact it isn't.
The swagelok tubing is perfect for air lines.
I have some 3/8" swagelok tubing for mine,... but I think I like the looks of the 1/4" better.
I guess I haven't been keeping up with your build.
I'm glad to see you got a Dropmember for your truck.
With the high caliber build you're doing,... your truck deserved one.
Subscribing!
Keith
Convert to disc brakes.
Old 03-06-2010, 11:46 AM   #21
jlaird
jlaird's Avatar
keith,
I like what you did with the through frame fittings and bringing the soft line right to the frame. I wish I had thought of that!
So yes, I finally bit the bullet and got the dropmember for the exact reason you stated. I will update my build thread soon...I'm waiting on a part from Nate.
Old 03-06-2010, 11:59 AM   #22
texastrendz
i used swagelock fittings on my dually project and could not stop them from leaking. let me tell you, you have to tighten the snot out of them. i hope you have better luck then i did. i was using 1/2 lines on my project with 200 psi pressure. maybe a smaller line and less pressure will be ok.
Old 03-06-2010, 03:52 PM   #23
lolife99
lolife99's Avatar
We use Swagelok fitting where I work all the time. Up to 3000psi.
They work great.
Usually just takes a turn and a half (8 flats on the hex nut) from finger tight, to make them leak proof.
Keith
Old 03-06-2010, 03:54 PM   #24
lolife99
lolife99's Avatar
Originally Posted by jlaird View Post
keith,
I still need to figure out a way to restrain the braided lines.
Maybe tie them to the upper a-arms like they did in the 73-87 trucks.
I really like the clamps from Made4You.
I ordered mine direct from Made4You,... but Summit Racing has them also.
Keith
Old 03-06-2010, 04:00 PM   #25
lolife99
lolife99's Avatar
jlaird,... If you ever get a chance to purchase a Swagelok brand tubing bender, buy one. There is no better bender in the industry. The even have a little tab on them that can be clamped in a vice to free up that extra hand that you need,... and don't have. Ha.
Keith
