Old 03-05-2010, 11:56 AM   #1476
daverod
SSN 706
daverod's Avatar
Re: Daverods project 66
I was thinking about putting these bags from SD ($200) on my 64. It already has the cut springs and I removed the bumper stops and brackets. How much more would the bags drop the front end? When all the air is out of the bags how low would it sit?
daverod is offline   Reply With Quote
Old 03-05-2010, 02:20 PM   #1477
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
that's how I was going to run mine. You wont be able to lay it on the frame in the front because of the crossmember, But that's the way to go, or make your own brackets.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 03-05-2010, 04:26 PM   #1478
daverod
SSN 706
daverod's Avatar
So when I let all the air out the crossmember would sit on the ground? Do you think I would have to change the steering set up? I guess this is as low as you go with aired out cross member on the ground.
Old 03-06-2010, 01:18 AM   #1479
ruffrida2005
you wont have to mess with the steering. This is mine without drop spindles and a small notch in the rear. Gives you an Idea.
Paul
Old 03-06-2010, 10:05 AM   #1480
daverod
SSN 706
daverod's Avatar
Sweet, I was worried about the steering. My truck has a lot of body roll.I thinking I need to put a sway bar on the front, maybe new shocks? I have a sway bar off a 71 sub. I going to see if it will work. Maybe something to do today. Is that the truck with the rusted roof? It looks good from here. I don't think I would ever buy a truck that's been painted. You just never know.
Old 03-06-2010, 11:50 AM   #1481
Strodder
Daring to be Different
Strodder's Avatar
Dave it will go as low in the front as the frame is where it touches to bump stops. Measure from the ground to the lowest part of the frame where the bump stops were. Then with the springs installed subtract the space between where the bump stop was and what would hit it. I hope that didn't sound too confusing. I wish I can draw you a picture.
I wouldn't install a sway bar at all. If you install the front and rear air bag controls independently and not connected to each other, like front and rear controls on 2 switches. If you have each bag adjustable you don't need a sway bar. Example is when the truck leans to the right the air in that bag will gain more pressure. If the air line is connected to the left bag along with the right bag, and controlled with 1 switch, when the pressure gains in the right bag it will transfer the pressure to the left bag. Causing it to lean. When the pressure stays in each bag it will keep it from leaning to that side. Are you really confused now.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 03-06-2010, 12:11 PM   #1482
SCOTI
SCOTI's Avatar
Independent air control will definitely prevent the pressure transfer lean. A sway bar is a very good upgrade as well. All modern vehicles have sway bars now for a reason (they work).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 03-06-2010, 01:20 PM   #1483
daverod
SSN 706
daverod's Avatar
Thanks for the info guys. I'm going to put the sway bar on. On my 64 (Work/Driver) I'm thinking about bags with no compressor for now. I want the front lower and I thought that would be a good way/ cheap way to do it. I'm going to cut some more off my spring today just to see what it does. I want more of the stink bug look. Right now it's just about level. On my 66 I will do the level control thing for sure.
Old 03-06-2010, 01:44 PM   #1484
Strodder
Strodder's Avatar
Yeah I'm not saying sway bar aren't good. But if you have the independent air bag set up you don't need them at all. My 56 Belair handled really good with hardly any lean. Besides if you want to play with the air bags like going side to side, and other stuff you can't with sway bars.
I got it this low without notching the frame or dropped spindles.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-06-2010, 02:10 PM   #1485
daverod
SSN 706
daverod's Avatar
Cool ride. When I get some $$ I'm doing it on the 66. "I want to be able to drive around all screwed up.
Old 03-06-2010, 02:13 PM   #1486
Strodder
Strodder's Avatar
There goes your tires.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-06-2010, 02:16 PM   #1487
SCOTI
SCOTI's Avatar
That's where our opinions differ & obviously there's not one, correct, one size fits all answer.
Sure, you can run w/o them, but they are a benefit for stabilizing the front suspension when using softer, street friendly spring rates. To me, bags fall into that category regardless of whether they're controlled independently or not. I've ran dropped C10's w/o a sway bar & then installed one.... what a difference they make on vehicles w/higher COG's.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-06-2010, 02:17 PM   #1488
daverod
SSN 706
daverod's Avatar
Loading up the sled when I got a killer idea for my tilt hood on my 66. I always wondered how people made them tilt. Now I have an idea. Now I just have to figure out how to keep it locked down.
Old 03-06-2010, 02:25 PM   #1489
Strodder
Strodder's Avatar
All I can say is I've installed hundred's of air bags on every thing from 47 Caddys, to brand new Tahoe's. With my Chevy a Nissan Z couldn't catch me on Mulholland Drive. With springs you need sway bars. With air bags if set up right it's not really needed.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-06-2010, 02:33 PM   #1490
daverod
SSN 706
daverod's Avatar
Ya but you never put air bags on a sled did you?
Old 03-06-2010, 02:37 PM   #1491
Strodder
Strodder's Avatar
Bring it over.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-06-2010, 02:41 PM   #1492
daverod
SSN 706
daverod's Avatar
I'm loading up now should be there in about 600/75=make it ten hours. So about eight your time. Enough goofing off I have a sway bar to install. I really have no idea of where the ends hook up to. I'm sure I'll get it figured out. Then I'm taking my puppy for a truck ride. Now where did I put those parts?
Old 03-06-2010, 04:18 PM   #1493
watahyahknow
watahyahknow's Avatar
some european cars have a verry nice cable operated latch with a small cone to catch the part on the hood that should work good enough on wat youre planning
i do think you need to reinforce the rear of the setup a bit so youre able to lift the whole hood from one of the sides without bending it up
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-06-2010, 04:19 PM   #1494
daverod
SSN 706
daverod's Avatar
Cut about 1/2 a coil off dropped about 2". Might be too much going for a drive.
Old 03-06-2010, 04:33 PM   #1495
Strodder
Strodder's Avatar
Looks better
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-06-2010, 05:28 PM   #1496
daverod
SSN 706
daverod's Avatar
Rides sweet. Did'nt bottom out once. The springs where making some noise. Checked it out. They are rubbing on the sides of the mount on top? I did'nt replace the part that holds the bottom of them in. Maybe it's important. I did'nt replace it before and did';nt have a problem. Dog loved his ride. Biker guy gave me the thumbs up. I need a posi.
Old 03-06-2010, 05:30 PM   #1497
daverod
SSN 706
daverod's Avatar
I'll have to see how my Olds works. Good idea
Old 03-06-2010, 05:58 PM   #1498
daverod
SSN 706
daverod's Avatar
The morph. Damn that was a good looking camper. Still remember the guy at dump wondering what the hell I was doing. By the time he figured it out I was gone and so was the camper. The money I got for the jacks paid for half the truck.
Old 03-06-2010, 06:10 PM   #1499
daverod
SSN 706
daverod's Avatar
Bubba why don't you go buy this for me.
Old 03-06-2010, 11:16 PM   #1500
bubba327
HOW long until spring??
bubba327's Avatar
When we finish what we started here, then we will talk buying about a new project. Congratulations on driving your truck. Just starting mine is a rush, Driving it will come soon.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
