Old 03-06-2010, 02:00 AM   #1
CARR33
No ebrake rear disc
I recently purchased a 67 swb fleetside from an out of state dealer (iowa). I live in maryland and could only view the photos. The truck has 4 wheel power disc and stops outstanding. But it has no ebrake. The rear calipers look just like most gm fronts. The bracket doesnt bolt to the bearing housing, its welded to the tube. My thoughts are to cut the bracket off and start from new with a kit from a reputable supplier, at least i'll know what i got. Any other suggestions? I've seen the add on small ebrakes but i dont care for them
CARR33 is offline   Reply With Quote
Old 03-06-2010, 02:24 AM   #2
capev86
Re: No ebrake rear disc
just get the factory rear disc from a 2000+ GM 1/2 ton (2 or 4 wheel drive) as they are 6 lug and have disc brakes on the back. you can't go wrong with factory R&D and we are talking same application (rear brakes on a truck) instead of an aftermarket setup using a mix of parts. you know the e-brake will be good on a factory setup.
capev86 is offline   Reply With Quote
Old 03-06-2010, 02:30 AM   #3
CARR33
I'm sorry i should have said it has five lug axles, but i'm with you on using factory parts. Thanks
Old 03-06-2010, 03:16 AM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
a board member - Glock35ipsc makes a bracket kit that uses 94-96 model Impala rear discs (5x5 bp) with 94-97 Camaro calipers and e-brake hardware. It bolts to the housing end like you mention. It is a mix of all GM stuff that you can use and still get replacement parts at any auto parts store. You can keep your current axle and wheels, and do it on the cheap if you don't mind hitting the salvage yards to get the complete Camaro rear setup.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-06-2010, 03:27 AM   #5
Flat 67
Junior Member
Flat 67's Avatar
How about using a drive line e-brake. That way the setup you have now wouldn't have to be changed. Just a thought.................Flat67
Flat 67 is offline   Reply With Quote
Old 03-06-2010, 11:17 AM   #6
OhOneWS6
OhOneWS6's Avatar
Glock does not offer them any more. CaptianFab does though.
OP, Pics of you setup would really help. You may already have the Impala rotors and calipers.
OhOneWS6 is offline   Reply With Quote
Old 03-06-2010, 12:17 PM   #7
capev86
my bad.....i was thinking model year not current mods on your rig when i mentioned the late model gm truck brake setup. personally i like to use a complete brake system as it was designed from the factory and i like truck brakes on a truck, not car brakes with an aftermarket bracket.....i might go that route on a show truck but not a street driven truck that hauls loads and tows stuff.
Old 03-06-2010, 03:09 PM   #8
Chevydude56
Chevydude56's Avatar
Can you post a picture of the setup? depending on the caliper used you may be able to replace it with one with a p brake The metric metric calipers came with parking brakes on the rear of some GM car
http://www.speedwaymotors.com/Garage...per,36779.html
1967 Suburban 292 3spd
1964 Chevy II wagon
1971 Monte Carlo 402BB
1964 Cadillac series 62 2dr
1964 Bonneville 2dr/ht
1967 GTO
1978 Chevy Van 30
1989 R30 Crew Dually Bonus Cab
Chevydude56 is offline   Reply With Quote
Old 03-06-2010, 04:44 PM   #9
grs
This co. can help you. I have rear disk on my 69. If their parts are bad they will replace them, and they pay the freight. You may have to buy the parts from a dealer, and not ABS Power Brake Inc. I got my system from earlyclassic.com The calipers have emergency brakes, and cables. One of my emergency brakes did not work, and they took care of it with no problem.
grs is offline   Reply With Quote
Old 03-06-2010, 04:47 PM   #10
OhOneWS6
OhOneWS6's Avatar
Exactly what I was thinking. A set of F-body calipers with integrated e-brake and the brackets from CaptianFab with the existing rotors.
Old 03-07-2010, 12:54 PM   #11
OhOneWS6
OhOneWS6's Avatar
I was thinking about this. Before you order any brake kit you are going to want to make sure what rear end you have. If someone took the time to weld the brackets for brakes they very well may have put a Ford 9" or some other rear end in your truck.
Old 03-07-2010, 04:29 PM   #12
new to this
I was able to find a set of rear brake calipers for a Cad. Seville that had the e-brake built in to the rear calipers.But i have also found a conversion kit on ebay for 399 for the 6 lug and 499 for the 5 lug.
new to this is offline   Reply With Quote
