Trailer Brake Controller, which is best?
I need to wire my 70 4x4 with Electric brake controls. Which is best for the money and how hard to wire up? Thanks
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
Re: Trailer Brake Controller, which is best?
I'm using a Prodigy made by Tekosha. I've used others but this is absolutely the best on the market. It can be adjusted to apply whatever braking pressure you want and you can select what pre load you want. Its really easy to wire and the instructions are simple. It will give you smooth firm braking without any nightmares. Check out the Tenkonsha web site and look it over. Shop around the net for prices and you can get it pretty cheap.
Junior Member
I have been using an older model Tekosha brake controller in my '92 GMC since I installed it just after I bought the truck in '92.
I have pulled two 5th wheel travel trailers and the controller works great. It was very easy to hook up. I also installed one in my father-in-laws F*rd and it was also an easy install. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Tekonsha Prodigy. Money well spent.
![]() ![]() Join Date: Dec 1999
Agreed. Have one in the my truck. The one in my avatar.
Easy install. Super easy to work.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
Thanks Gents appreciate the help.
Take Care Ron
#7 | |
I have the Tekonsha Voyager in my 94 since new and have never had any issues with it had they made the prodigy back then I prolly would have bought it.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
