hey guys, i may have a line on some factory buckets
![]() but...... the slider lever on one of them is missing and the seat doesnt lock into place. and its missing the springs. now, is there anyone out there that can tell me if the slider part of the seat is the same as burb or blazer high back buckets?? and i wonder if i can just unbolt the slider part from the seat itself and get another set from pick n pull off a burb bucket?? any idea here?? thanks ALOT!!!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
Re: question about factory buckets
The passenger side does not slide, there are four brackets that bolt it right to the floor. The driver side tracks are different from Burbs and Blazers.
i understand that. sorry if i wasnt clear... i have a line on some 74 lowbacks and i wanted to know if the brackets on the seat will interchange from the easier to find highbacks?
Yes, truck and Blazer highbacks through about '85. Burbs are different from the Blazers.
Just to clarify, the sliders are not separate from the mounts.
Slots go on anything!
Blazer brackets are completely different that pickups or burbs. The floor in a Blazer is completely flat (at least where the seat mounts to). Your bench seat slider bracket may work, but you would have to compare them to see for sure.
1974 Jimmy- 5.3/4L80e/NP241 |
ok! forget i ever said blazer... so the slider part doesnt unbolt from the seat itself?
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() Last edited by menace121978; 03-07-2010 at 10:44 PM. |
i got it. thanks Jonboy... i'm going to try and get these babies if the shipping doesnt kill me!!
yeller
Here is a pic of my truck bucket seat brackets.
![]() Can't answer your question, but the pics might help others who can.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#10 | |
Those look great . Nicely restored .Any new pics of the truck? Frank
Born and proudly residing in a Red State ! |
yeller
Frank, at the moment, no new pics. I will try to get some his week or next weekend.
Jeff, thanks for that pic buddy. i'm going to compare to my bench slider now
So I'm confused, I thought you were asking if you could use other seats on the sliders you found.
no, the other way around buddy. i need different/new sliders.
#15 |
Im in you same position. I just picked up a set of low back blazer bucket seat for only $20 dollars the bad thing is they dont have bracket. Let me know what you find out about the brackets please...
#16 |
i'd say your best bet is to pull a pair of brackets off some highback buckets at a pick n pull and get the floor mount tab while your there also and everything from what i understand will bolt together.
#17 |
yeller
#18 |
more times than i can count... i have a comprehension problem though
#19 |
can some one clarify for me, will the suburban brackets work on the blazer buckets I have? has any one made their own brackets? if so post pics please..
#20 |
bump same question^
