Old 03-03-2010, 12:49 PM   #1
GKsport67
GKsport67's Avatar
Post F/R disc brake setup
Anybody running Front/Rear disc brake set up? post pics with specs(if u will)
GKsport67 is offline   Reply With Quote
Old 03-03-2010, 02:26 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: F/R disc brake setup
Do you have a link? Price?
Hart_Rod is offline   Reply With Quote
Old 03-03-2010, 02:45 PM   #3
GKsport67
GKsport67's Avatar
Im actually asking if anybody's useing the f/r disc setup on their trucks. Im not selling this product. just using the pic
Old 03-03-2010, 03:15 PM   #4
Hart_Rod
Hart_Rod's Avatar
I was just asking for a link to get more information about the setup?
Old 03-03-2010, 03:23 PM   #5
GKsport67
GKsport67's Avatar
Oh i just googled front & rear disc brackes...n took that photo from there.
Old 03-03-2010, 05:46 PM   #6
Burb
Coordinator of Synchronicity
Burb's Avatar
Is it for your '67 C-10 ?
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 03-03-2010, 10:41 PM   #7
OhOneWS6
OhOneWS6's Avatar
Do a search in the suspension forum. There are multiple ways to do it. I personally am going to use the LT1 F-body calipers with a set of CaptianFab's brackets. Lots of guys are using Impala SS calipers but I want an e-brake so I don't have issues getting it inspected in TX.
OhOneWS6 is offline   Reply With Quote
Old 03-04-2010, 09:46 AM   #8
GKsport67
GKsport67's Avatar
Yes it is. If i could cut the cost & get MISC pieces from salvage yards i would. Like the guy say Impala parts. I will look deeper into what fits my 67 C-10.
I do want front & rear disc brakes though
Old 03-04-2010, 11:07 AM   #9
OhOneWS6
OhOneWS6's Avatar
this would be a good time to do a 5 lug conversion if you have not already done it.
Old 03-04-2010, 11:11 AM   #10
GKsport67
GKsport67's Avatar
I haven't yet. im so ready. This is a crucial part of my build. I like the NOSEDIVE stance. 4x6 drop f/r disc setup is ideal for me. They say the truck might lock up because the bed is so light. I wouldn't care,i need to see the RED calipers protruding through the Bonspeed "VINSPEEDS"
Old 03-04-2010, 07:11 PM   #11
68 short step
truck im building for a member is running a very simular kit...
68 short step is offline   Reply With Quote
Old 03-06-2010, 09:44 PM   #12
GKsport67
GKsport67's Avatar
Looks like good quality,whats the cost on a set?
Old 03-06-2010, 10:51 PM   #13
GKsport67
GKsport67's Avatar
They tell me i could use a 73-87 chevy c-10 front disc on my truck & a 96 implal rear disc in the rear. Can i do that?
Old 03-07-2010, 01:37 AM   #14
OhOneWS6
OhOneWS6's Avatar
Short answer is yes.
Old 03-07-2010, 04:57 AM   #15
darthwall
the 73-87 I think you have to use the spindles and ball joints at the minimum or you can bolt up the whole cross member and be done with it the backs I dont know find out so I can do it
darthwall is offline   Reply With Quote
Old 03-07-2010, 09:43 AM   #16
GKsport67
GKsport67's Avatar
Talking Re: F/R disc brake setup
How much this would cost? So my parts list should be a 73-87 front cross member & a 96 impala rear end? that'l be genuine chevrolet
Old 03-07-2010, 10:34 AM   #17
mbgmike
They do not make this kit for our years. Our price on the Kit for a 2000 chevy pickup and up run $1250.00. pretty pricey
Baer makes a front 14" and rear 13" kit with parking brake
We sell them also but here again its pricey
Kit 4301389b Front runs $1965 our price
Kit 4302126b Rear runs $1243 our price
mbgmike is offline   Reply With Quote
Old 03-07-2010, 12:48 PM   #18
OhOneWS6
OhOneWS6's Avatar
For the front that would work. A lot of guys do that conversion. It also gives you the newer style control arm shafts.
The impala rear is not a direct bolt in. CaptianFab makes some brackets that bolt on and use either an Impala caliper (no e-brake) or a different set of brackets that use the LT-1 F-body caliper (integrated e-brake).
You will also need a disc/disc master and proportioning valve.
If it's in your budget, There are also kits available as mgbmike has mentioned that include everything you need for a disc/disc conversion.
Price is going to vary widely. It depends on what you ultimately end up using and how you source the parts. It could be anywhere form a few hundred to a few thousand.
Personally, I am going with the F-body calipers. I have the brackets from Captainfab and can tell you they are quality pieces. I have not completed my install yet so I can't give you all the details.
Captainfab F-body brackets.
http://67-72chevytrucks.com/vboard/s...d.php?t=382633
If you search the suspension section there are several threads about disc/disc conversions.
Old 03-07-2010, 11:09 PM   #19
GKsport67
GKsport67's Avatar
Yes sir!
Old 03-07-2010, 11:15 PM   #20
GKsport67
GKsport67's Avatar
If you search the suspension section there are several threads about disc/disc conversions.[/QUOTE]
Ok so the front set up 73-87 c-10...done.
What type of rear end i need to put the 96 impala disc on it?
What i need from the 96 Impala? CaptainFab got the brackets to install then.
What else i need to the complete this,master cylinder etc
My wheels will be 4' backspacing all around.
Old 03-07-2010, 11:55 PM   #21
OhOneWS6
OhOneWS6's Avatar
You really should search the suspension forum. You have to dig a little but I promise you the answers are there. Several members have done this conversion. All you are going to use from the Impala is the rotors.
Lots of info in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=340444
