Old 03-06-2010, 11:23 PM   #1501
daverod
SSN 706
daverod's Avatar
Re: Daverods project 66
I'm loving mine. It's a buzz saw. Figured out my springs were'nt in right. Had to turn them alittle. After I did that no more noise and it sits even lower. I wish I lived in Boise. Congrats on your truck. I just want to buy the truck for a furture project. Thats ok is'nt it. It won't really be a project.
daverod is offline   Reply With Quote
Old 03-06-2010, 11:32 PM   #1502
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
That's the truck witht he jacked up roof. I really need to take a wire brush to the seam sealer and see what's really going on. Wont be for a little while. I haven't been able to work on the truck. I'm building my son's a moster swing set.
Now get back to work.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 03-06-2010, 11:46 PM   #1503
daverod
SSN 706
daverod's Avatar
I hate stuff like that. Stuff with instructions and parts with numbers and stuff. I always make my wife put that stuff together, or at least read it and tell me what to do. Good luck with it. What size of air tank do I need?
Old 03-06-2010, 11:52 PM   #1504
daverod
SSN 706
daverod's Avatar
Originally Posted by daverod View Post
Rides sweet. Did'nt bottom out once. The springs where making some noise. Checked it out. They are rubbing on the sides of the mount on top? I did'nt replace the part that holds the bottom of them in.
Ha, there was no part holding the bottom of spring in. Different truck parts I guess. The spring just sits in the pocket but it has to be sitting in there the right way. It was wacked. I just turned it alittle and in set down the way it should have been. Now it's even lower. Guess I'll have to order a sway bar for lowered trucks. The one I have won't work.
Old 03-06-2010, 11:54 PM   #1505
ruffrida2005
Oh it's nothing that is bought. were builing it ourselves.
The air tank size depends on if you wanna play or if you just wanna go up and down when you get in and out. My truck just had a 3 gal tank at first in that pic. Only front and back. I'm going to run a 8 Gal now, 8 valves and I wanna play a little at first. A 5 gal is a good all around tank. Remember you need to check the rateing on the compressor to see what size tank they will fill. Most Viars are rated for a 5 Gal. That's why I'm running 2.
Paul
Old 03-07-2010, 12:03 AM   #1506
daverod
SSN 706
daverod's Avatar
Sweet ,now I know. I can live with building stuff as long as there's no instructions. I love it even better when the instructions are in like 12 different languages. A picture is ok as long as it's in English..
Old 03-08-2010, 09:09 PM   #1507
daverod
SSN 706
daverod's Avatar
Parts fairy dropped off some new u bolts. They were larger then the old ones. Had to drill new holes, what a pain did'nt wait to spend 20 on a new bit. Gott my arms and tires mounted. Can't figure out why it won't go all the way to the ground. In think my upper arms are hitting the frame and stopping it from moving down? If I stand on the front it will go all the way.??
Old 03-08-2010, 10:04 PM   #1508
ruffrida2005
You have to notch out at the top of the spring cup so the upper arm will go lower.
Paul
Old 03-08-2010, 10:07 PM   #1509
ruffrida2005
http://c10forum.com/forum/showthread.php?t=4257
Paul
Old 03-08-2010, 10:10 PM   #1510
daverod
SSN 706
daverod's Avatar
I don't get it? I'll have go look. I was just looking at my tires compaired to my 64 they are huge.
Old 03-08-2010, 10:25 PM   #1511
daverod
SSN 706
daverod's Avatar
Looks like they notched it to get access to the bags. Good idea I'll do it. Still don't see why my frame is'nt on the ground. I guess with my engine in there it will be. Just has me worried. My arms look really close to the frame. they touch it. I was thinking they were bindiing. Nice link good info thanks Paul
Old 03-08-2010, 10:26 PM   #1512
ruffrida2005
did you see it before I posted the pic and the link. Just cut a whole it in. everyones doing it. It's all the rage.
Paul
Old 03-08-2010, 10:28 PM   #1513
ruffrida2005
You dont need to access the bag from there. Go take a look at it and I bet your arms are hitting right here. Look and a bunch of other pics of bagged trucks and you'll see the same.
Paul
Old 03-08-2010, 10:51 PM   #1514
daverod
SSN 706
daverod's Avatar
I don't know? the upper arms are'nt even close to the part that is notched in the pictures. They move in the other direction. Are you popping pain meds like smarties again.
#17 From the linky.
"They are cut out for access to the top of the bag. It looks as though he welded in the upper bag plate instead of bolting it on. When you do that the only way to access the top of the bag is to cut an access hole. IMO even if you bolt that plate on, it is a good idea to cut an access hole to make it easier to swap the bag out."
Old 03-08-2010, 11:45 PM   #1515
protrash64
Resistance is Futile
protrash64's Avatar
Could be balljoint bind or the cross shafts binding up a little. On my burb they were tight but the BBC should push 'em down no problem.
Lookin' really cool daverod ........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-08-2010, 11:59 PM   #1516
daverod
SSN 706
daverod's Avatar
I think your right. When I stand on he front it hits the ground. Time for some front bags. Took another look at my sway bar. I think it will work. I just have to get it up high enough to drill some holes. No, I don't have a fancy lift, yet. After those u bolt holes I'm sick of drilling.
Old 03-09-2010, 12:11 PM   #1517
protrash64
protrash64's Avatar
I had to drill those on my p/u and do it from underneath. I know what your saying!! I was very glad when they finally fit in place.
Old 03-09-2010, 09:53 PM   #1518
daverod
SSN 706
daverod's Avatar
Put my sway bar on. Went on real easy. The hardest part was grinding down the rivets on the crossmember. Went for a test drive. I thought I was in a Vette. What a difference. Well worth the time and money. Hour and a half and it was free off an old parts truck. I'm sure it would be better if I had new rubber.
Old 03-09-2010, 10:42 PM   #1519
ruffrida2005
man I have been taking my pain pills, I'm on some good stuff. I was trippin about the notch. You notch the crossmember for lift. You may or may not have a problem with it. put a motor in it and watch it lay out.
Paul
Old 03-09-2010, 10:44 PM   #1520
daverod
SSN 706
daverod's Avatar
Old 03-10-2010, 01:48 AM   #1521
SCOTI
SCOTI's Avatar
Skip the 'new' rubber & go w/poly. Energy Suspension makes various sizes in black. Some are fluted w/a zerk fitting in the bracket so they can easily be serviced when lubing the other front end parts.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 03-10-2010, 10:06 AM   #1522
daverod
SSN 706
daverod's Avatar
Found a dealer near my house. I'll check it out today.
Old 03-10-2010, 10:18 PM   #1523
protrash64
protrash64's Avatar
Daverod.....I just noticed that you used the pancaked x-member that you made. Did your engine stands sit ok or were they modified too??
Old 03-10-2010, 10:27 PM   #1524
daverod
SSN 706
daverod's Avatar
I haven't gotton that far. My engines not in my 66. Do you think I'll have to mess with the engine mounts? I don't know if I'm going to use it or not. I'm thinking a DM might save me a lot of problems. But this is cheap and done.
Old 03-11-2010, 01:08 AM   #1525
Captainfab
60-66 Nut
That part of the crossmember remains in the original location. So the engine stands will work without modificaton.
