Old 03-10-2010, 02:57 AM   #1
Mikey's68
Steering Column Shift Indicator Question
I found a non-tilt steering column off a 68 Sierra Grande at the wrecking yard. It was missing the pointer housing, shift indicator housing and lens. LMC lists the pointer housing for the column for that year but not the indicator housing and lens. It only list those for 1971-1972.. Can you use the 71-72 lens and housing? Thanks guys
Mikey's68 is offline   Reply With Quote
Old 03-10-2010, 10:40 AM   #2
Clyde65
Clyde65's Avatar
Re: Steering Column Shift Indicator Question
I am in the same place as you, Mikey. I will wait a reply.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
