![]() Join Date: Sep 2007
Part 2 Of Small Parts For Sale!!
all prices plus shipping
*1 complete ashtray assy 68-72 12.00 * 1 68-72 ashtray glide assy (out of my 68) 5.00 *1 68-72 complete mirror assy, good chrome, mirror is in good useable condition but my no means perfect. SOLD *1 ac cab center piece vent housing (behind dash) 5.00 *1 turn signal switch arm, good driver condition 5.00 * brake booster to pedal adjustable bar, (a must when converting to power brakes!!) SOLD * sbc thermostat housing SOLD *2 rear end trac bar mounting studs, 4.00 each *1 set 3/4 core radiator mounting upper brackets in good shape. SOLD * 1 set passenger door hinges in good shape. 15.00 *1 v-8 manual clutch z-bar SOLD *1 v-8 points GM distributer in good shape. 20.00 *1 set lower tail gate swing hinges in good shape SOLD *2 71-72 throttle pedal plastic mounting triangle. no broken tabs at all. 6.00 *1 steering column adaptor harness (straight to curved) SOLD *1 pigtail harness to convert cluster from 3 guage to 7 guage 7.00=pending= *1 brake light switch with pigtail 5.00 *1 smallblock engine lift stop 67-70. 20.00 *1 set Chevy headlight buckets and retainer rings in good shape, 25.00 * 1 68-72 back window SOLD *1 set of good teal visors 25.00
1967custom Last edited by michael bustamante; 03-15-2010 at 06:53 PM. |
Roadtrip!
![]() Join Date: Feb 2003
Re: Part 2 Of Small Parts For Sale!!
If the steering column adaptor from straight to curved will work for a van tilt conversion, total to 55744... Eric
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again... 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Is it done yet?
Are these 3 or 4 core mounts?
*1 set 3/4 core radiator mounting upper brackets in good shape. 20.00 If they are 4 core ill take them.
1972 Chevy SWB New 383 Stroker/350 Turbo Some day i'll paint it John 3:16 MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=398108 Last edited by Southern C10; 03-08-2010 at 07:53 PM. |
i should be just fine, its a gm part from my 68. lets say 13.00 shipped to you
1967custom |
theyre 4 core mounts with the rubber in them. I was using them on my 4 core rad before I went to an all aluminum rad. 25.00 priority to your door
1967custom Last edited by michael bustamante; 03-08-2010 at 07:58 PM. |
Is it done yet?
Sounds good. Shoot me a pm with your payment info.
1972 Chevy SWB New 383 Stroker/350 Turbo Some day i'll paint it John 3:16 MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=398108 |
pm sent. thanks!!
1967custom |
ttt
1967custom |
Hello:
If it works for you, will also take the following and pick them up with the others when next I get to ALB. 1 68-72 complete mirror assy, good chrome, mirror is in good useable condition but by no means perfect. 15.00 * brake booster to pedal adjustable bar, (a must when converting to power brakes!!) 15.00 * sbc thermostat housing (good for replacing those chaep chrome ones that warp) 5.00 *1 v-8 manual clutch z-bar 20.00 *1 set lower tail gate swing hinges in good shape 10.00 *1 brake light switch with pigtail 6.00 * 1 68-72 back window 25.00 Please LMK. Thanks, CCCC
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
sounds good to me neighbor, let me know when you wanna come into town.
Ill pm you my #
1967custom |
![]() Join Date: Feb 2009
I will take the guage cluster 3 to 7 guage pigtail shipped to 46037.....(question: does this work if you don't have the tach for the 7th guage? also I have never seen this piece before, is this something you made?)
no I took it off a harness that had the 5 guage set up (I meant to put in 5 guage, sorry) no tach no vacuum guage. I saned this cuz when you convert from 3 to six guages you have to mave around a bunch of pins and stuff so Ive read so I thought itd be easier to splice in the correct harness. The conversion set up procedure is on the GMC pauls website if you want to look it up.
1967custom Last edited by michael bustamante; 03-12-2010 at 07:27 PM. |
ttt again
1967custom |
Roadtrip!
Got the wiring adaptor today and it looks fine. Thanks, Eric
#15 |
good deal man. thanks again
1967custom |
