#126 |
Re: Autometer Cluster Projects
#127 |
![]() Join Date: Feb 2001
You can find the white face 3 3/8 water temp and oil pressure still. Every so often you can find a fuel pressure guage 3 3/8 like above or a tranny temp guage. I have watched for a long time and I haven't seen any fuel guages. I have a 3 3/8 fuel pressure guage extra but I wouldn't mount it inside of a cab.
#128 |
Mudder if that fuel pressure gauge doesn't come with an isolator they do make one. Fuel goes to it then something like antifreeze goes up to the back of the gauge.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#129 |
I didn't know anything about it but just what I read about it. I'm not even sure if it is all there. Shame cause it would sit in that center hole really nice.
#130 |
Chevy Lover Till The End.
Very nice! I'm in the process of doing mine the same way as your's but I'm doinging white faced gauges. What did you use for the 33/8 hole and the turn signal holes?
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
#131 |
low n' slo
![]() Join Date: Mar 2009
i dont want to sound like a cheapo..but i was in oreilly the other day and they had some cool reasonably priced gauges in there. they kinda look like this.
![]() would they be worth the money? that one is an autometer gauge i think, like 54 bucks. but i think the others are a bit cheaper.
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#132 |
I would want them all to match each other even if they were different brands.
#133 |
its to bad you cant take them apart as eazy as a regulair cardash , there a lot of custom skins available for gauges wish would equal them verry nicely
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#134 |
72 chevys 4 life
what size of aftermarket gauges fit in our bezels? idk if someone has asked cause i dont have time to look through
I dont call it being young and dumb....I call it young and havin fun ![]() |
#135 |
Here is mine I just finished. I have Autometer speedometer and tach and the bottom four are Peterbuilt gauges.
#136 |
I didn't get to use the white faced gauges.
#137 | |
More Cowbell....
My cluster has somewhere in the neighborhood of $700 in it. New gauges, new bezel, wiring harness parts, etc.... Or labor only? (please PM me about this, since I am not a vendor). I just do this every now and then. And....I just happen to have a few (spare) 3-3/8" gauges in the ProComp color scheme (black with white letting). They are (if I remember correctly) oil temp gauges. Now these are identical to Water temp....even down to the sending unit. Same thread pitch, same sensor bulb, etc... The only difference is the actual word "Oil" instead of "Water". So, technically, I figure you can install it to monitor either.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 03-10-2010 at 03:32 PM. |
