throttle body spacer
i was interested im putting a throttle body spacer on on 01 with a 5.3L, im installing a cold air intake already and just Ciriouse if anyone here has done a spacer and if there worth the money. thanks in advance
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
Re: throttle body spacer
Good question??? Anybody???
Save your money, T/B spacers have little to no effect on port injected engines.
![]() Join Date: Sep 2005
the new style of vehicles the computer compastes for the increased air flow so it really make no more power
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2015 toyota Tacoma Daily 2012 Subura outback 2000 Tahoe 5.3l 420k 1999 honda accord General manager for Marco's Carwash & lube |
#5 | |
It's like clinebarger said, there is no effect on engines that don't mix the fuel with the air before the intake manifold, like a TPI or carbed engine. If you add one to your LS-base motor, like the 5.3, it will only make a whistle sound and that's it, no power increase, NO mpg increase. And spiraling the air pattern there before the intake manifold doesn't do anything except disturb it's flow before it goes to each cylinder... ABSOLUTELY POINTLESS! can't believe some of these "respectable" companies are still pushing that crap and getting away with it... ridiculous. |
| Bookmarks |
