Old 03-11-2010, 08:38 PM   #1
AirSpeed
AirSpeed's Avatar
Pressure relief valve on door jamb
I am painting my 72 GMC and when I took the relief valve off the door jamb I noticed that the steel at the bottom of the vent is slightly bent in, not flat. I dont know whether it is supposed to be that way or not, I looked at the other door as a reference and just noticed it has no relief valve on the jam. Now I have two questions, is the slight bend under the valve stock and why is there no valve on the passenger door? It seems like both should have one.
Thanks for any info! Aaron
AirSpeed is offline   Reply With Quote
Old 03-11-2010, 08:52 PM   #2
Sammy
Re: Pressure relief valve on door jamb
I never noticed mine being bent. But only 1 relief on my 71 GMC (DS) also. If I recall correctly 75 and newer had 1 per door.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-11-2010, 09:08 PM   #3
71 super
71 super's Avatar
71 was the first year for the valve and one of the ways to determine year of your cab, there are others as well but will not go into that. They only use the valve in the driver's side and it should be flat under the valve. The valve also gets a thin rubber oring around it as well to help seal against the "b" pillar.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 03-11-2010, 09:11 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
It's all tied in to the fuel tank vent/evap system. Nothin' to do with venting the cab.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-11-2010, 09:17 PM   #5
AirSpeed
AirSpeed's Avatar
Gary
It actually vents the pressure from the door when it closes, it makes it easier to close the door. It makes a big difference, my 69 doesnt have one ofcoarse and the door is much harder to close, specially with the windows closed.
Old 03-11-2010, 09:18 PM   #6
bignbad
bignbad's Avatar
I am i missing something.I never herd of p.r. valve on the cab.what is it for?whats does it look like?Any pictures?My '72 doesn't have one.
'72 chevy k20
'06 H-D Springer softail
http://www.bluemooncruisers.com/
http://www.enginecycle.com/
~Eric
bignbad is offline   Reply With Quote
Old 03-11-2010, 09:19 PM   #7
AirSpeed
AirSpeed's Avatar
Thanks everyone! I will flatten out the area at the bottom. Aaron
Old 03-11-2010, 09:22 PM   #8
AirSpeed
AirSpeed's Avatar
If you have a 72 it should be on the door jamb on the drivers side, it's around 6" tall, plastic and has a rubber one way flapper type valve on the inside. Its there to make the door close easier, without one it's much harder to close the door, my 69 doesnt have one and its much harder to close the door.
Old 03-11-2010, 11:06 PM   #9
leddzepp
Moderator
leddzepp's Avatar
This is correct. It is not tied into the fuel tank or EEC.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
