Old 03-08-2010, 09:49 PM   #201
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Air Ride Install - '69 Chevrolet SWB Stepside
Kyle, I'd be happy to help ya when you get to that point.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-10-2010, 05:19 PM   #202
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Doug, your work looks very nice.
I want to see the new wheels!
LOW DOUGH is offline   Reply With Quote
Old 03-10-2010, 09:34 PM   #203
tcb-1
tcb-1's Avatar
no pics right now, low dough. however this is the guy that has welded up several wheels for me in the past:
http://www.rallyamerica.com/hotrod_trucks/index.html
thinking seriously about the 17 x 7 smoothie with '52 Chevy caps......
just thinking about it right now, $190 a wheel for steelies is kind of high. especially when you have to buy 5!
Doug
Old 03-11-2010, 10:01 PM   #204
tcb-1
tcb-1's Avatar
dropped a print of my valve bank mounting plate to my fabricator yesterday and picked the finished product up this afternoon. gotta love waterjet tables. precise, even cuts.
decided to take the tank ot to make it easier to mock up the mounting holes. also thought about my valve arrangement. it'll be tight, but compact and easy to work on. oh yeah, I plan on making a lift off bed hatch to access the valve bank, tank, and compressor. the hatch will be cut from the original bed wood making it "kind of" stealth and unobtrusive. those plans are finally coming together.
here's the plate with a mock up of the valve layout. I have to flip the valve mounting brackets to get this layout, but that's pretty straightforward. I wanted to mount them to a sturdy surface that protected them from road debris and copious amounts of water spray.
once I get the mounting holes drilled, it's off to get paint.
the bed mods will be next. stay tuned.........
Doug
Old 03-11-2010, 10:06 PM   #205
VA72C10
VA72C10
VA72C10's Avatar
Nice Idea and I can't wait to see it with the bed done...
Old 03-11-2010, 10:47 PM   #206
sourkraut
sourkraut's Avatar
looks good doug! can i ask why you are mounting them on top and not on the bottom so you dont have to cut a hole in the bed? is it to protect them from road damage? i am ask cause i dont know know squat about air bagging! not in my future but i like the idea.
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 03-11-2010, 11:15 PM   #207
texastrendz
may want to drill some drain holes in it, just in case you get caught in the rain.
texastrendz is offline   Reply With Quote
Old 03-11-2010, 11:16 PM   #208
tcb-1
tcb-1's Avatar
kraut,
good question.
1. I wanted easy access to the guts of the system.
2. in case I have a a failure on, let's say a valve, I can get to easier than if I'm aired out and have to get under the truck. I'm an engineer by trade and I always try to design for the worst case scenario. call me paranoid. plus I love the technical aspect of the system and kind of think it would be neat to show it off!
3. oh and I will be raising the bed floor, so I will be modifying it slightly anyhow.
Doug
Old 03-11-2010, 11:18 PM   #209
tcb-1
tcb-1's Avatar
the 10 degree kick up in the front will take care of that.
Doug
Old 03-11-2010, 11:21 PM   #210
sourkraut
sourkraut's Avatar
cool, sounds good to me!
Old 03-17-2010, 02:45 PM   #211
tommyd241
tommyd241's Avatar
Originally Posted by tcb-1 View Post
call me crazy, but I think I found another set of rims so these may be up for sale. keeping the 17" tires though.
I'm never satisfied......
I'm not sure if it was already mentioned, but what size tires are those? Your truck is awesome BTW.
tommyd241 is offline   Reply With Quote
Old 03-17-2010, 02:52 PM   #212
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Here ya go...
General 235/55/17's
More info:
http://67-72chevytrucks.com/vboard/s...d.php?t=368720
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-17-2010, 02:57 PM   #213
tommyd241
tommyd241's Avatar
Thank you Sir.
Old 03-17-2010, 10:30 PM   #214
Slick67
Sofa King Crazy!!
Slick67's Avatar
Still watchin, silently watchin and waiting. Everything looks so sanitary....kinda scary! Hope mine looks like that to everyone on here.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 03-18-2010, 09:33 PM   #215
tcb-1
tcb-1's Avatar
figured out the valve placement and installed them tonight. wow, brass is expennnnnsive! I placed and mounted the valves in this manner in case I need to pull one for maintenance. I tried to build this in a modular fashion, meaning you can take pieces out without dismantling the entire system....... and I can add another compressor later by simply adding a mounting plate. I also took thermal expansion and contraction into mind when I used air line from the tank to the valves. I wanted to hard pipe this connection, but went with flexible air line. call me technical, I know. sorry, I'm an M.E.
next on the list is wiring the valves and compressor. should be getting to that and posting pics this weekend.
getting closer!
Doug
Old 03-18-2010, 09:42 PM   #216
bobbo
Droppin' It Like It's Hot!
bobbo's Avatar
That is looking great, Doug! Can't wait to see it in person! Will it be done for Magic Dragon?
Robert
Life Member
RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09
1969 1500
Norwood, MO 2007
Big Sandy, TN 2008 Had nothing to do with the forklift!
Kirkwood, MO (Midwest Meet 2009)
Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014
SUPPORT THE SITE HERE!
bobbo is offline   Reply With Quote
Old 03-18-2010, 09:51 PM   #217
tcb-1
tcb-1's Avatar
Rob, I still have the granny tranny SM465 in it and that thing is crap on the interstate. I was hoping to have installed an M21 or 22 this winter to get better mileage and higher speeds on the highway, but ...... well you see what I've been up to instead.
may be out of long distance runs again this year. boooooo!!!
Doug
Old 03-18-2010, 09:56 PM   #218
bobbo
bobbo's Avatar
Well hurry and get it done! So just make it to the important ones locally, that's what I try to do but somehow the truck is attracted to KC. Really look forward to hanging again!
Robert
Life Member
1969 1500
Norwood, MO 2007
Old 03-18-2010, 10:07 PM   #219
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Swapping your SM465 out for an M21 or M22 isn't going to improve your highway performance. They all have 1:1 top gear ratio, none of them being an overdrive box.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-18-2010, 10:16 PM   #220
SATownChevy
SATownChevy's Avatar
looks good dude. im doing something similar with my 68, just a little farther behind.
View pics of my truck - 1968 Chevy C10 SWB - Photobucket
I'm not wasting money on my truck, I'm helping to rescue the economy one mod at a time.
SATownChevy is offline   Reply With Quote
Old 03-18-2010, 10:19 PM   #221
tcb-1
tcb-1's Avatar
yes, I guess your right, all Muncies all have a 1:1 final ratio. my top end just plain sucks, and I have a 3.07 rear! wish I could run 75 to 80 without turning the amount of rpm's I see.
guess I'm either going to have to go with an overdrive, a 5 speed, or auto. I love my manuals though!
Doug
Old 03-18-2010, 10:54 PM   #222
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
nice detail there.
Old 03-18-2010, 11:35 PM   #223
lolife99
67-72 parts collector,…
lolife99's Avatar
Doug,... what kind of RPMs are you turning?
Those 3.08's should be perfect for the highway.
Keith
Convert to disc brakes.
Old 03-19-2010, 12:48 PM   #224
ERASER5
ERASER5's Avatar
How tall are your tires? They look normal height to me. 3.08 gears should run well at highway speeds no matter what engine.
Most modern trucks run 3.55 or lower with OD. Just say'n.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-19-2010, 01:12 PM   #225
tcb-1
tcb-1's Avatar
I think the last time I was out on the interstate, @ 75 mph I'm turning 4200 rpm. I guess I'm just used to a 5th gear and 80-85 mph speeds, with the engine turning 2300 to 2500 rpm.
maybe an overdrive is the way to go.
on another matter, isn't the SM465 a very heavy transmission? still may be nice to loose some weight, regardless if I still have a 1:1 final Muncie. hummmmmmm.......
Doug
