Old 03-12-2010, 07:06 PM   #1
orange prostreet69
steering/front end question
I have a 69 c/10 2wd shortbed. I put disc brakes, A-arms, and power steering off of a 86 1/2ton 2wd chevy. I want to replace inner and outer tie rods. My question is do I have to get tie rods for a '86 or my '69? I was assuming for a '86 but I am not sure. Need some help guys! Thanks!
orange prostreet69 is offline   Reply With Quote
Old 03-12-2010, 07:25 PM   #2
michael bustamante
michael bustamante's Avatar
Re: steering/front end question
i BELIEVE YOU HAVE TO CHANGE YOUR CENTER LINK AND PITMAN ARM AS WELL AS THE INNER AND OUTER RODS BUT iM NOT ABSULUTELY SURE, iM SURE SOMEONE WILL CLAIFY HERE IN A MINUTE.
1967custom
michael bustamante is offline   Reply With Quote
Old 03-13-2010, 12:21 AM   #3
OhOneWS6
OhOneWS6's Avatar
I believe MB is correct. You will need to use all the 86 parts.
OhOneWS6 is offline   Reply With Quote
Old 03-13-2010, 12:23 AM   #4
69 longhorn
3rd that crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-13-2010, 07:06 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You get tie rod ends to match whatever steering linkage you used. When you did the swap, did you also install the late model tie rods and center link along with the spindles and arms ? If so, yes, get the later model ends.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-14-2010, 07:37 PM   #6
orange prostreet69
Thanks guys. Yea all I got for the front end was the '86 a-arms and spindles with rotors and also power steering box. The steering linkage I have is still for my '69. My second question is can a power brake booster and master cylinder for a '69 work with this setup? Thanks Again!
Old 03-14-2010, 10:05 PM   #7
OhOneWS6
OhOneWS6's Avatar
If you are changing from drum to disk you will need a disc master and proportioning valve. I believe you will also need the front brake lines from the master to the caliper. for disc brakes. i think they are a different diameter line.
There is an FAQ on this conversion in the suspension forum. I didn't look at it but I bet most of you questions are answered there.
