05-07-2003, 05:22 PM | #1 |
What's better Air Induction: Open Element or Stock with a Duct?
Well, I have both an open element Chrome Air Cleaner, as well as the stock one. BUT, my stock one has been modified. I cut off that little plate that's on the inside of the round portion (I guess it's called a "air director", Swervin did the same mod), as well as cut out the guts for the Heat Choke Stove valve. Here's a pic with the current 3" Cold-Air duct.
Would that work better than just a normal open element cleaner, or would it work worse? I'm using a K&N Filter (fits both stock and open element) |
05-07-2003, 06:27 PM | #2 |
You have all kinds of stuff going on there!
I like the battery hold down You would probly get slightly more air flow out of the open element, but it would be warmer air. I would stick with stock, but get a stock snorkel. They are cheap at your local dealer (brand new). If I remember correctly I paid like $7-8 for a brand new snorkel. I know for sure I did not pay over $12 for it.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
05-07-2003, 06:53 PM | #3 | |
05-07-2003, 07:51 PM | #4 |
ROCKET POWER!
Ever been in a crash with that truck? Probably not because you wouldn't use that string to hold the battery down. 'Tis just a friendly suggestion.
-Axle
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
05-07-2003, 09:34 PM | #5 | |
05-07-2003, 10:06 PM | #6 | |
Getting cheap tie downs that BOLT in place is a good idea. What I used cost about $10 and can be found at most auto stores - just the two long bolts with wing nuts and a cross bar. -- Mike
http://home.houston.rr.com/chevy73/ |
05-08-2003, 12:51 PM | #7 | |
I just think the stock snorkels give a nice clean appearance. They are black and dont attrack as much attention, thats all. EDIT: Speaking of crashes. A friend of mine had a similar hold down. Hes a jack@$$ and decided that driving off road around the dirt field by the mall would be a blast. Which it was . Anyway his battery came loose some how and jumped into the fan. It was an optima battery. It destroyed one cell and the thing still worked fine, but didnt crank as well. One more reason to own an optima!
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 05-08-2003 at 12:54 PM. |
05-08-2003, 04:15 PM | #8 | |
Re: What's better Air Induction: Open Element or Stock with a Duct?
Bill |
05-08-2003, 04:20 PM | #9 |
"The dude abides"
Nothing looks cooler then opening up the hood of a truck and seeing a massive, chrome, open element, filter under there. And nothing sounds cooler then an open element when the quad opens up and starts howling.
However, the cold air induction is better. Traveling down the highway you are getting a ram air effect plus you are not sucking in that hot engine bay air. Hence why muscle cars use the ram air hoods, the cowel induction, etc, etc.
RockMan 1993 Chevy Silverado C3500 1 ton dually 1994 Honda Civic 1969 Oldsmobile Cutlass S 1953 IH Farmall Super M New to the fleet: 1992 Subaru Loyal |
05-08-2003, 07:52 PM | #10 |
You get what you pay for
I think this looks pretty cool too.
Mike 1985 Chevy C-10 |
05-09-2003, 02:11 AM | #11 |
Rollin' Member
Where did you pick that up Mike? I want one.
:: 1977 C10 cheyenne :: :: 1973 new yorker brougham :: for sale - $1,500 lofat productions |
