03-10-2010, 10:00 PM | #1 |
Help with Collector bolts loosening
Can anyone recommend a solution for my situation. I am running a ball type collector system without a gasket. The bolts seem to loosen over time and develop leaks. I use lock washers and lock nuts which resist loosening because of the thread pattern. Does anyone know of anything else to use? High temp thread lock? The bolts are 2 inches long so I can't use the bolts with the self locking mechanism because they only come in 1 inch.
1969 GMC Wideside SWB 400ci/TH400/373/Disc Brakes/Leaf Springs 1992 Chevy C3500 Ext Cab Dually Silverado 454 TBI 2007 Chevy Corvette ZO6 427ci 505HP Last edited by CHEMPOWR; 03-10-2010 at 10:02 PM. |
03-10-2010, 10:03 PM | #2 |
Junior Member
Re: Help with Collector bolts loosening
had a similar issue with the 57 collectors. i went to the muffler shop and they just retightened and spot welded the nut to the bolt. never loosened again.
67-72 Truckless for the moment Member# 1126 The one that got away http://customclassictrucks.com/featu...001/index.html |
03-10-2010, 10:05 PM | #3 |
I could do that. Thanks for the suggestion. Be nice for something less permanent but will keep that in mind. Thanks
1969 GMC Wideside SWB 400ci/TH400/373/Disc Brakes/Leaf Springs 1992 Chevy C3500 Ext Cab Dually Silverado 454 TBI 2007 Chevy Corvette ZO6 427ci 505HP |
03-10-2010, 10:07 PM | #4 |
Redefining LowBudget
use high temp forma gasket like a thread lock
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
03-10-2010, 10:22 PM | #5 |
use 2 nuts jammed together. i had the same problem until i double nutted mine. no more leaks.
03-11-2010, 08:32 AM | #6 |
Thanks everyone. Now I have more than one way to skin a cat.
03-11-2010, 11:26 AM | #7 |
longer bolts with springs in between the flange and bolts seem to work pretty good. I have had a couple sets of ball flanged header to exhaust connections and that has worked form me. Seems like a honda I had was like that from the factory, and kinda mimicked that setup. like this
http://www.summitracing.com/parts/WLK-35129/?rtype=10 Last edited by junkman; 03-11-2010 at 11:31 AM. |
03-11-2010, 01:55 PM | #8 |
Parts and more parts
Have you tried using teflon tape on the bolt threads? I use it on my header flange bolts and I do not have any issues with the bolts coming loose.
Frank |
03-11-2010, 05:53 PM | #9 |
Watch out for your cornhole !
High temp locknuts will take care of your issue. They are steel and do not have nylon insert like typical lock nuts. Instead they are crimped slightly when manufactured to make them self locking. Every jet engine out there uses them and they see very high temperatures and obviously don't loosen up in use.
03-11-2010, 05:58 PM | #10 |
NASA also uses the style nuts Tx Firefighter is talking about on things that are affected by temperature
03-11-2010, 06:16 PM | #11 |
Hey, it's reliable enough for the space shuttle so....
03-11-2010, 10:34 PM | #12 |
I have used these on a few different jobs. Work great.
http://www.nordlock.com/default.asp?url=2.16.37
1972 K2500 Long Box 400/350 |
03-12-2010, 08:19 AM | #13 |
Thanks everyone!
03-12-2010, 10:38 AM | #14 |
STAGE 8 LOCKING BOLTS. I'VE USED THEIR HEADER BOLTS & THEY ARE GREAT , & THEY SEEM TO MAKE EM FOR A BUNCH OF APPLICATIONS NOW. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
03-12-2010, 10:57 AM | #15 | |
"All metal" lock nuts are known as "prevailing torque nuts". There are a few different types available.
One style looks very much like a nylon insert type. It has the ring around the top, but it is "crimped" to interfere with the threads. Tightening this nut "stretches" the crimp, holding it in place. Another use a "crushing" of the nut into somewhat of a triangle. This puts more pressure on the threads too. Others use various forms of "distorted" threads. The stock rocker arm nuts are a good example of these. You just have to be aware that most of them will lose their holding ability with repeated removal-reinstallation.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. Last edited by LONGHAIR; 03-12-2010 at 10:58 AM. |
03-13-2010, 10:36 AM | #16 |
Thanks everyone!
