Can Anyone identify This Frame?
I got this frame from a friend that had it in his backyard for awhile. He said he did not know what it was from but it looks very similiar to youngrodders frame. Is this style frame good for a subframe, or complete frame.Attachment 558404
Attachment 558405 Attachment 558406 Attachment 558407 Attachment 558408 Last edited by Fat Mike; 04-22-2010 at 08:46 PM. |
![]() Join Date: Mar 2007
Re: Can Anyone identify This Frame?
Fat Mike-
This looks just like my G-body frame. Mine was modified where the car body sits. I can't see from your pics because the floor is covering it. The PO modified mine in the back to mount the fuel tank. Also with this frame the steering box in in the way of the radiator. I also had to shorten the radiator (core) support I think 4". BY doing this, I had to get a different radiator to fit. I didn't want to spend big money on a custom radiator but I found on that works good. I can help with any measurements that you need if you go this route. Marc |
I was think of using a 47 frame that someone cut front and rear off. I was thinking of using the subframe and rear off this g-body frame to make one complete frame.
#4 | |
I didn't realize that you are building a 59. I take back the comments about the shortened core support. I don't know how much my measurments will help you but I will offer anything that I can. Marc |
Mike it also looks like an A body frame (chevelle, GTO). It's hard to tell exactly from the pics. My front clip is from a 67 chevelle.
Kim |
Youngrodder I am also building a 47 gmc which i was planning on using these parts for. I really can't decide if I want to use the original frame or make one with parts.
Kim 57 I plan on cleaning the frame up alittle and will try to post some new pictures. Is this a good subframe to use thou? I would like to use it on one of my frames. |
A-body and G-body are very simular as far as I can tell from some quick research.
Here is a list (compliments of Wikipedia) of all the G-body cars my year. Buick Century (1978-1981) Buick Regal (1978-1987) Chevrolet El Camino (1978-1987) Chevrolet Malibu (1978-1983) Chevrolet Monte Carlo (1978–1988) GMC Caballero (1978-1987) Oldsmobile Cutlass Supreme (1978–1988) Oldsmobile Cutlass Calais (1978–1984) Oldsmobile Cutlass Cruiser (1978-1983) Oldsmobile Cutlass Salon (1978-1981) Pontiac Grand Prix (1978–1987) Pontiac LeMans (1978-1981) Mine I believe came from a 78 Grand Prix. That was also what I used when ordered different chassis parts over the years. Good luck Marc |
#8 | |
I like the frame. It rode great with just the coil spring suspension and sat very low. Building a frame from scratch is out of my comfort level so I really can't speak to that. I am sure it comes down to time vs money. Marc |
#9 | |
Kim |
Thank you guys for the info. I'll post more pictures when I get it cleaned up alittle.
AD Addict
You'll need to know if it is metric or not when you are ordering repair parts. Looks A/G to me. I'm not certain but I thought A was pre-77 and G was 78 and up and G was metric.
Is it me or does the shape of the rear diff cover look like a 7.5 inch?
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
rear looks like G body but that front hub is throwing me off. Also the motor mounts aren't write for an Abody.
Just so you know there is an adapter on the one hub that was showing. The other thing is that I think the rearend is posi because when i picked the frame up the hubs spin the same direction.
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 |
#15 |
don't think it was an A body really think it's G body...
http://67-72chevytrucks.com/vboard/s...d.php?t=385860 Last edited by southbounddee; 03-12-2010 at 08:32 PM. |
#16 |
i'll tell ya,..i've stripped an 1985 chevy caprice classic and i would put $$$$ on it that it's the same,.. what you got had four doors, better photos would help...
http://67-72chevytrucks.com/vboard/s...d.php?t=385860 |
#17 |
AD Addict
Maybe some dimensions might help. Wheel base and track width. THAT will definitely rule one direction or the other.
#18 |
Cancer Survivor in the making.
I'm not sure I could tell a G body from an A body. It does look enough like the G body I used to have that I would believe that is what it is.
But those front hubs? They don't look right for anything I've seen.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron. Steve@OldSub.com OldSub.com . MaxwellGarage.com . OldGasTowRigs.com |
#19 |
Looking at it again it looks like it has the 5mph front bumper mounts. I think those came after the A bodies were done. The front hub looks like its off a truck.
Kim |
#20 |
Insane In The Membrane
There should be a VIN stamped in the frame. I believe it would be on the driver's side frame rail near where the firewall would be. But I have also seen them on the second to last crossmember.
#21 |
that IS a knock off hub for a wire wheel, you know like the lowriders use, the left is white and the right is red, put $$$ on that one for sure!
#22 |
This is correct!
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
