Old 03-13-2010, 07:41 AM   #1
70Custom10Nut
70Custom10Nut's Avatar
Question Rams horn manifold question
Do the factory Rams Horn manifolds come in different sizes? How well do they flow? I've seen them called "Rams horn Headers", but they all look about the same. My engine is a little warmer than stock, so I don't need super hi flow headers. Actually, I'm beginning to think the lack of back pressure in my system (shorty headers into 2 1/2 inch tube and mini turbo muffs) is causing the hesitation I have.
Reason I ask is I can get a pair for next to nothing, and as another board member said, it does away with the constant gasket failure on a header setup. Cnut
70Custom10Nut is offline   Reply With Quote
Old 03-13-2010, 08:44 AM   #2
JimKshortstep4x4
Re: Rams horn manifold question
Rams horn exhaust manifolds come in 2" and 2 1/2" sizes. They probably will not flow as well as your headers.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-13-2010, 10:08 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Jim
I agree that the 2 1/2" Rams Horns won't flow as good as headers but didn't they come stock on the high performance corvettes?
LockDoc
Leon
Old 03-13-2010, 10:28 AM   #4
OhOneWS6
OhOneWS6's Avatar
I thought the Vette ram horn and truck ram horn were different. The Vette ones are the better flowing ones. The truck ones with the kink at the bottom are the more restrictive ones. Not sure how the truck ones that are not kinked compare to the Vette ones.
OhOneWS6 is offline   Reply With Quote
Old 03-13-2010, 11:08 AM   #5
70Custom10Nut
Thanks for the info. I'm going to measure them before I buy them. I think they're the 2" though, and wouldn't do what I want. Thanks again, Cnut
Old 03-13-2010, 12:56 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
LockDoc
Yes. Dunno how they might differ from any other rams horns... Both my '65 Corvette (327/365, same as fuelly but carbureted) and my '66 327/350 (highest output on hydraulic lifters) had factory rams horns.
Sure wish I still owned those cars...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 03-13-2010, 09:40 PM   #7
Jim 383
not cheap but speedway motors sells TruRam manifolds for chevys and y block f**ds
Jim 383 is offline   Reply With Quote
Old 03-14-2010, 12:14 PM   #8
Wrenchbender Ret
The Corvette type Ramhorns w/ 2 1/2 in. outlets are reproduced now & are not expensive.
Wrenchbender Ret is offline   Reply With Quote
Old 03-15-2010, 10:22 AM   #9
KSCHEVYUP
KSCHEVYUP's Avatar
If anyone is interested.
Speedway Motors sells a 2- 1/2" Corvette Style exhaust manifold for $59.95 each.
These were patterned off of the early 60's 327 Corvette
If someone knows of a better price maybe they will post up here?
Ron
1972 C30 Cheyenne Super
1971 C10 (Parts truck)
KSCHEVYUP is offline   Reply With Quote
