Old 02-21-2010, 05:40 PM   #1
Aaron Burr
Aaron Burr's Avatar
Random 62' C20 questions
Bought a thermostat gauge switch deali and some 12 gauge wire. I know I have to remove the plug between cylinder 1 and 3 to stick the gauge in the hole to get in the water jacket.
Question the first. Will removing the plug cause a bunch of fluid to drain out?
2nd question. Do I just wrap the wire around the top and jam the other end into the relay box by the fan?
I know it's supposed to go in the 86 slot. So I guess I need an end piece or something. But it's the wrapping of the wire around the top of the thermostat that's buggin' me. It doesn't seem right.
Oh, the part looks like this.
Aaron Burr is offline   Reply With Quote
Old 02-21-2010, 07:20 PM   #2
cliffy
Re: Random 62' C20 questions
I know it's supposed to go in the 86 slot. So I guess I need a end piece or something. But it's the wrapping of the wire around the top of the thermostat that's buggin' me. It doesn't seem right.
there is a proper wire connector for that, slips over the head sideways.
my o/l says the truck has a vibration at 65 mph..I said its ok, it goes away at 90.
cliffy is offline   Reply With Quote
Old 02-21-2010, 07:43 PM   #3
Aaron Burr
Aaron Burr's Avatar
Thanks. I guess that's the little black plastic piece in the lower right hand corner of the pic. I thought it was for the relay box.
Is there a special tool needed to remove the plug from the block? It has a square hole in it, all I could think of was using a ratchet extender.
Old 02-21-2010, 10:51 PM   #4
Aaron Burr
Aaron Burr's Avatar
Yup. Ratchet extender. I just need the right size...and a female spade connector for the relay box. Who knew?
After I do that tomorrow, and assuming the fan works, I figured I'd move on into the speedometer. Mine doesn't work since I had the 700R4 put in. I don't feel like paying a ton of money to have someone else hook it up so I was wondering if anybody here had installed one.
Ah. One last question concerning the thermostat. Anyone have a good idea how to route the electrical line?
Old 02-22-2010, 02:05 AM   #5
Captainfab
60-66 Nut
So this sending temp unit you have, you're using it to control an electric fan? Is it the original style for your truck or is it designed to control a fan?
Old 02-22-2010, 03:33 AM   #6
Aaron Burr
Aaron Burr's Avatar
Oh jeeze... I'm a bike guy so bear with me.
The fan is electric. It worked until I got the 700R4 shoved in there. I added a triple cluster gauge, water, amps and oil because I didn't think relying on the "idiot lights" was the way to go for an older truck. I had someone else do the install because I was busy moving to another state and didn't think it would be a big deal.
Apparently sticking the ambient bulb into the top of the block necessitated removing the regular sensor that was hooked up. I just figured buying a thermostat switch and sticking it into the appropriate plug and running a wire to the relay box by the fan would work.
I'm getting the sense this may not work the way I think it should.
Oh, and the part is from NAPA. They looked up the appropriate part for my make and model so I'm assuming it'll kick in at 185.
Old 02-22-2010, 10:01 PM   #7
Aaron Burr
Aaron Burr's Avatar
Hmm. Turns out I bought some tools I didn't need, couldn't remove the part I wanted to and haven't finished the repair I was planning on. Why...this is just like working on a motorcycle!!!
It starts with the plug between cylinder 1 and 3.
It's too small for a 1/2 ratchet extender and a 3/8th has some play. It doesn't matter because that sum b!tch is like super glued in there or something.
Next, the relay box by the fan.
Upon disconnection, it doesn't look likely I'll be sticking any female spade couplings in there.
That's O.K. There's always the relay box under the dash.
Hmmm. No numbers on it but at least it has an empty slot.
Well, I'm stumped. I may have to pay some guy to blow the plug out...and then I'll just start randomly connecting stuff until something works...or explodes...at this point I can go either way on this one.
Old 02-22-2010, 10:35 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Get an old 3/8 extension and stick it into the plug and whack it with your impact wrench. I've never found one yet that wouldn't come out. The 3/8 extension will fit tight enough to remove it.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-22-2010, 11:01 PM   #9
Aaron Burr
Aaron Burr's Avatar
Wait...I get to hammer on stuff? FINALLY!!!
I'll give it a whack tomorrow. Thanks for the tip.
Old 02-22-2010, 11:07 PM   #10
Tx Firefighter
I meant hammer on it with your impact wrench.
Old 02-22-2010, 11:30 PM   #11
Aaron Burr
Aaron Burr's Avatar
As long as I get to whack something.
I went to the store this evening and the little green turn signal light stayed on. Signals worked fine. Only when the truck warmed up did the light go off.
So yeah, I'm whacking on it manana. It's just asking for it.
No, really. I tried squeezing the impact wrench in there and it wont fit...stupid headers..
Old 02-23-2010, 05:30 PM   #12
Aaron Burr
Aaron Burr's Avatar
So I put a piece of pipe over the end of the 3/8 driver to gain some leverage. Pulled and felt it give. Took the extender off and turned the 3/8 by hand, felt it give some more, sweet.
Yup. Now the plug hole is kinda stripped out. Man, I kick ass. On the plus side, maybe now the 1/2 ratchet extender will fit in there.
Old 02-23-2010, 11:42 PM   #13
Aaron Burr
Aaron Burr's Avatar
Well it's not all sour apples and sandy lollipops. I think the reason my turn indicator light stays lit is because the running light on the right side is either going out or the wiring is bad/loose/shorting out.
In the WTF column, I fired up the C20 after a pit stop and heard a real brief CHAW! noise as it turned over. Starter?
Oh, and I'z taking the engine over to a fellow who used to work on these things when they first came out so I'll let him tackle the stripped out plug.
Old 02-24-2010, 05:38 PM   #14
Aaron Burr
Aaron Burr's Avatar
Sweet mother of Louie Chevrolet! Look what I found clear over on the other side of the engine!
Pop that cap off and...
Buh? Let's look in the cap.
Hmmm. Looks like the cap has a little male unit that goes in the top of the temperature dealie. I'z gots the wrong part. (See top of thread)
Anybody know what the right part is for this job?
Old 02-24-2010, 07:18 PM   #15
Aaron Burr
Aaron Burr's Avatar
So I called up the fellow who installed the 700R4. http://www.sonomacountystreetrodz.com/
He looked at this thread and told me I need a late model GMC thermostat dealie that has the plastic end so it couples right up.
Back to NAPA...which for me is about a 30 mile drive one way.
Old 02-25-2010, 06:26 PM   #16
Aaron Burr
Aaron Burr's Avatar
And a waste of time. I have to take the part off for him to order the right one. Also, I may have to do some major rewiring all around simply to find out where everything goes. It's half good, half rats nest, which is why I missed the temperature dealie in the first place.
Oy. As a new guy I have a request for all you guys building and reselling....KEEP NOTES...so the next guy will have more of a clue. None of my guides seem to be relevant to this half stock half custom job.
Old 02-28-2010, 06:16 PM   #17
Aaron Burr
Aaron Burr's Avatar
Oh, by the way Aaron. When you take the temperature switch dealie out...yes, a whole bunch of coolant will indeed come flying out. Even if you partially drain the radiator.
The good news is the part is in San Diego and will most likely show up some time next week.
Old 02-28-2010, 07:30 PM   #18
LILRED66
LILRED66's Avatar
One more good reason to carefully inspect a moderate or highly customized truck. Unfortunately, it is "Buyer Beware", not seller beware, so make sure you know what you are buying before purchasing or, at least, know what it takes in time and money to get it right.
LILRED66 is offline   Reply With Quote
Old 02-28-2010, 07:40 PM   #19
Aaron Burr
Aaron Burr's Avatar
Oh when I first saw it I was in love, and anybody who's been in love knows what a huge pain in the butt that's all about.
But yeah, when I popped the hood for the first time it was pretty much "what the fug?" and "Hmmm. that don't look right."
So yeah, I knew this was going to take some work but man oh man....the guy before me should have checked out the "I'm drunk" thread before doing any work on this truck.
Old 03-03-2010, 09:36 PM   #20
Aaron Burr
Aaron Burr's Avatar
O.K. got the part...after getting the wrong one from NAPA. Thanks NAPA! But I still have no fan operation. Soooo. It must be a bad wire, or bad connection in the relay box. So now I need a pigtail sensor. Hopefully one that comes with some wire.
After that I'll replace the relay box.
Good thing I'm so even tempered.
Ha. Ha. Ha.
Old 03-13-2010, 09:00 PM   #21
Aaron Burr
Aaron Burr's Avatar
I'm about ready to waste good money and pay someone to fix this thing.
Replaced the temperature gauge dealie. Replaced the shroud connector. Replaced the wire.
Still no fan.
It works when I touch it with that pointy screwdriver thing with the light bulb in it but that's it.
WTF!?!?
Old 03-13-2010, 09:32 PM   #22
daxloves
daxloves's Avatar
Ummm. sounds like one of the wires may have gotten hooked up to the wrong thing. Somehow "the little green turn signal light" got connected to the temp sender. Hence the light going out when the truck warmed up. I dont know fro shure or how but you may want to look into that.
daxloves is offline   Reply With Quote
Old 03-13-2010, 10:24 PM   #23
Aaron Burr
Aaron Burr's Avatar
Thanks Mr. Loves. However, I done fixed that problem. It was a couple of loose connections. (I live way out in the boonies where there are a lot of washboard roads)
Now I'm all about getting the fan to work.
I hate to admit it, but I may simply bypass the whole sensing unit and hook the fan up to a manual switch.
It just bugs me because the sensor should work. No, really. It's all hooked up with brand new junk and everything.
It just doesn't go on.
