Old 03-14-2010, 07:52 AM   #1
w314speed
Question-Rear Sliding Glass
What NOS rear glass weatherstrip was used with the factory sliding glass?
It appears that the one needed for the slider is the one w/o the trim molding?
Somebody out there knows!! Thanks, Dan
w314speed is offline   Reply With Quote
Old 03-14-2010, 08:30 AM   #2
cdowns
cdowns's Avatar
Re: Question-Rear Sliding Glass
depends weasther the truck in question came with or without the trim// you could get it either way
Old 03-14-2010, 09:38 AM   #3
w314speed
I understand you could get with trim and w/o. The question is what rear glass weatherstrip was used to install a rear slider? Thanks, Dan
Old 03-14-2010, 09:41 AM   #4
JimKshortstep4x4
Are you asking about the actual window seal or the fuzzie that the sliding windows slide in?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-14-2010, 09:56 AM   #5
w314speed
window seal
Old 03-14-2010, 10:52 AM   #6
cdowns
cdowns's Avatar
if you have trim you use seal for trim if no trim you use seal for no trim
Old 03-14-2010, 10:56 AM   #7
mbgmike
Not sure you can get an oem gasket for these anymore. I will do some more checking with our suppliers. So a NOS might have to be the way to go. We sell a replacement gasket(black Only) for the aftermarket sliders for $50.00. But its for replacing a oem plain window with the aftermarket slider. Not sure its the same as the factory slider
mbgmike is offline   Reply With Quote
Old 03-14-2010, 11:03 AM   #8
Hart_Rod
Hart_Rod's Avatar
My sliding glass has the stainless trim....
Hart_Rod is offline   Reply With Quote
Old 03-14-2010, 11:13 AM   #9
mbgmike
Is that a factory window? none of our suppliers (like 6) do not offer a rubber with the S/Stl trim.
Old 03-14-2010, 11:28 AM   #10
Hart_Rod
Hart_Rod's Avatar
I'm not sure Mike. It was in the truck when I got it. Is there a way to tell?
Old 03-14-2010, 11:36 AM   #11
mbgmike
I don't know the differance between the factory and the aftermarket. I grew up with these trucks new and no one I knew had a slider cause all my friends and relatives had basic trucks. could not afford fancy stuff. Most I did see was in camper trucks and did'nt really look at them much. I am sure GM did not make them. One of their suppliers did I would guess. They may be the same as aftermarket one now.
Old 03-14-2010, 12:06 PM   #12
Hart_Rod
Hart_Rod's Avatar
My 68 SWB had a topper on it at one time also which is probably why they put the slider on. I've been looking for an aluminum topper to put back on it, but finding a period correct aluminum one is turning out to be difficult. If you need anymore pictures let me know.
Old 03-14-2010, 01:02 PM   #13
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I have always thought that the original sliding windows were the aluminum/stainless outlined windows, not the black ones. I have been known to be wrong once or twice though. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 03-14-2010, 01:44 PM   #14
johndawelder
johndawelder's Avatar
My original sliding back window has just the black seal,no stainless trim.I either got it from LMC or GMCpauls.Can't remember which.
johndawelder is offline   Reply With Quote
Old 03-14-2010, 02:03 PM   #15
John H.
John H.'s Avatar
Dan,
Here is what the Chevy book shows w/o stainless for a slider.
3940758 71-72 Ser 10 thru 30 (cab) w/sliding rear window
71-72 ser 10 thru 30(cab) (exc. C.C., C.S.)
3940756 71-72 Ser 10 thru 30 (Cab) W/C.C. C.S. (exc. sliding rear window)
If you need the WS wo stainless, I have an NOS I would sell for price of Repro.
John
John H. is offline   Reply With Quote
Old 03-14-2010, 02:53 PM   #16
John H.
John H.'s Avatar
Name:  72 GMC 100.jpg
Name:  72 GMC 103.jpg
Name:  72 GMC 072.jpg
Name:  72 GMC 071.jpg
Name:  72 GMC 073.jpg
Here was my 72 Sierra Grande 72 with factory slider and 19K original miles.
Old 03-14-2010, 02:59 PM   #17
chevy71super
My 72 super has a factory rear slider - SPID option number 1 A2810 Rear Window Sliding. The frame is aluminum with stainless steel trim normal to all supers. Doug
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 03-14-2010, 05:56 PM   #18
71blksuper4x4
SWB 4x4 Collector
See that is what I meant by my first statement. The factory sliding windows are stainless framed windows. The black framed windows are aftermarket windows. I do agree however that your upper trim package trucks would get the stainless trim weatherstrip, and the base models would get black rubber. Trevor
TREVOR
Old 03-15-2010, 12:56 AM   #19
chevy71super
Right you are Trevor! Doug
72 Cheyenne 4X4 SB
Old 03-15-2010, 05:35 AM   #20
w314speed
Guys, I appreciate all the info!!! It appears that the slider could have come both ways, with the parts book painting a different picture! I was always confused why? Chevrolet and GMC, actually GM as they did it in the cars as well, would each use different suppliers for the same part. I would guess the slider that will accept the ss trim allows clearance and the other dosen't. Thanks for everyones feedback and John H for the wonderful pics of your gorgeous 72 BB SG. I'll PM you on the seal. Thanks All, Dan
