Old 03-14-2010, 01:04 PM   #1
shark66
Drop Coil Springs
I am looking for a front 3" drop lowering spring and did not know which was the best brand to buy. I have heard bad things about several companies and was hoping I could get some input. Thanks
shark66 is offline   Reply With Quote
Old 03-14-2010, 02:06 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Drop Coil Springs
I bought 1" lowering springs from Chisholm Suspension about 10 years ago, and one of them sagged another inch within a year. I would not recommend them, but it appears they've gone out of business anyway. Hopefully another member can provide a positive recommendation.
Old 03-14-2010, 05:14 PM   #3
likaroc13
Rollin' Old Skool
i ran Western Chassis dropped spindles & springs on my old 93 fullsize Chevy, & they were nice...my 88 S-10 blazer had 3" drop coils too, but i'm not sure what brand...i know DJM & Belltech are other companies you could check with
Old 03-14-2010, 11:42 PM   #4
62fresh
question? i decided to crank the tosions loose to lower the front end, would it effect it
at all if i wanna go with a 2" lowered coil as well? or just go with the torsion lowering?
62fresh is offline   Reply With Quote
Old 03-15-2010, 01:06 AM   #5
Captainfab
60-66 Nut
I assume you're talking about the rear coil spring? If so then that won't really have any effect on the front. That will just drop the rear. It all depends on what stance you want.
Old 03-15-2010, 02:09 AM   #6
62fresh
sorry i meant the front with lowering the torsions and doing a lowered
shock in the front effect the ride quality at all?
Old 03-15-2010, 06:26 AM   #7
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Drop Coil Springs
torsion bar lowering
http://67-72chevytrucks.com/vboard/s...d.php?t=325329
2" Front Lowering Springs for '60-'72 Chevy 1/2 ton truck
http://67-72chevytrucks.com/vboard/s...d.php?t=328003
Early Classic's
http://www.earlyclassic.com/home.aspx
1960-62 Front Suspension Upgrade
http://67-72chevytrucks.com/vboard/s...d.php?t=366828
Classic Performance Products
http://www.classicperform.com/6092chevtrk.htm
1960 Torsion bar removal
http://67-72chevytrucks.com/vboard/s...d.php?t=302899
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-15-2010, 09:15 PM   #8
shark66
Has anyone used CPP lowering springs? If so, how do they hold up?
Old 03-15-2010, 10:15 PM   #9
62fresh
1Bad62Pro/Street thats the info i needed thanks bro
