Old 03-14-2010, 10:58 PM   #1
78swest
78swest's Avatar
15 inch wheel on 3/4 ton axles
i know its possible i have seen it but what do i need to do to make it work hub grinding? anybody?
78swest is offline   Reply With Quote
Old 03-14-2010, 11:09 PM   #2
Meatman
Meatman's Avatar
Re: 15 inch wheel on 3/4 ton axles
This is for Dana 60, but it might give you somewhat of an idea.
http://coloradok5.com/d60calipergrind.shtml
Daily-94 K2500 350 5spd extended cab longbox
Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack.
Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881
My 01 TA and 88 Formula hide in the garage. :-)
Meatman is offline   Reply With Quote
Old 03-15-2010, 12:56 PM   #3
ghettoluxury
ghettoluxury's Avatar
You gave to grind a little bit off of the calipers, mainly the casting flash. I used this oppertunity to make my calipers completely smooth, but that was just for a custom look. If you still have drum brahes on the back then you won't have to do anything to them.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
