Old 03-12-2010, 02:21 PM   #1
Brad
Out of the carpool lane.
Brad's Avatar
Question Installing tail light trim-where do I drill holes?
I'm installing 69-72 tail light trim on a truck that didn't originally have it and I don't want to screw it up. Does someone have a diagram that shows how and where to drill the holes for the clips?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-12-2010, 03:57 PM   #2
chevy1969
Re: Installing tail light trim-where do I drill holes?
You and I are in the same boat. I'm going to install uppers, lowers, tailgate and tail light moldings on a 69 SB that never came with them.
My best bet has been wrecking yards for the cab hole placement's, but finding a SB has yet to happen..... even finding a LB with moldings is tough.
If you do find some info. on this, please post or let me know?
Life is short, so play hard!!
chevy1969 is offline   Reply With Quote
Old 03-12-2010, 06:24 PM   #3
68gmsee
Active Member
68gmsee's Avatar
ttt
Here's a pic, if it helps. It's from my 68, but IIRC the hole placement is the same on all of them. I think the little holes are from the PO trying to keep the old ones in place after they fell off.
68gmsee is offline   Reply With Quote
Old 03-12-2010, 06:36 PM   #4
chevy1969
Thats awesome!! What are the chances of you having pics of the tailgate molding holes or even the bed side molding holes??
Rookie here, what does IIRC stand for?
Thank you......
Old 03-12-2010, 07:01 PM   #5
allancdelco
allancdelco's Avatar
Here is a picture of the entire rear of mine.
Hope this helps.
If it aint broke then you aint tryin hard enough.
HotRodandGunClub.com
allancdelco is offline   Reply With Quote
Old 03-12-2010, 08:09 PM   #6
chevy1969
Thats awesome, Thanks Allan!!
Anybody else have any molding hole pics??
Old 03-12-2010, 08:11 PM   #7
71 super
71 super's Avatar
The easiest method that I found is to take a water based marker vis a vie or similar and first mark the location of the retainers for clips on the trim pieces. Lay the pieces in position and make a small mark on the bed, centering the two marks you made on the trim. Remove the trim and center the the mark in the tailight area and drill approx. 4 5/16 holes and the appropriate sized holes for the two retaining screws located on the inboard side of the trim. Install your clips and press into place. I used this method on my 4x4's new sides and had 0 problems. take your time and measure twice. I did mine with a three year old helping and it turned out great. Hope this helps- oh be sure to limit the depth of the drill bit as you drill, if you go too far you could puncture the bedside.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 03-12-2010, 10:40 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Re: holes for the rest of the bed.
The rest of my truck bed molding holes would not be the same. I believe it's only the tailight holes and maybe the tailgate that are going to be similar. They made some changes on the side molding after '68.
On mine the side molding follows the contour of the wheel well like the one pictured below.
http://www.lmctruck.com/features/cb/cbml5.htm
Old 03-12-2010, 11:00 PM   #9
70c/10barebone
Junior Member
70c/10barebone's Avatar
Brad, Hope this is what your looking for.
1969 Tail light trim assembly instructions.
[IMG][/IMG]
[IMG][/IMG]
Let me know if I can help you with anything else from the Assembly Manual.
Craig
70 C/10 LWB 250
70c/10barebone is offline   Reply With Quote
Old 03-13-2010, 01:14 PM   #10
Brad
Brad's Avatar
Wow! Thanks for all the excellent responses. I've been running around for quite awhile with just the upper tailgate trim in place. Hopefully I'll get around to doing this today.
Old 03-13-2010, 02:36 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
IIRC = If I Recall Correctly
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 03-14-2010, 10:36 PM   #12
Brad
Brad's Avatar
Ok, I drilled 5/16" holes and tried to put the trim on and totally mangled it and bent it all up! It looks like 3/8" or bigger holes would have worked better but I don't want to drill too big if it's supposed to be 5/16". This sucks. Now I've got to buy a whole new set of trim. I need some help here guys.
Old 03-15-2010, 12:13 AM   #13
GruntMoanCough
GruntMoanCough's Avatar
Manual calls for 11/32" holes (aftermarket clips maybe need bigger holes). Did you get my PM?
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 03-15-2010, 01:41 AM   #14
Racinaround
Racinaround's Avatar
It took hours to find this I think im need to file stuff better on my PC
This has a ittle more info
http://67-72chevytrucks.com/vboard/s...d.php?t=221881
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
Old 03-15-2010, 04:35 PM   #15
Brad
Brad's Avatar
It looks like the best way to put the bezel on is to attach the clips first and then press it all on to the fender? I did that with the 5/16" holes and bent the crap outta the bezel. I'll drill the holes out to 11/32" and try it again. These bezels are like working with soft, malleable lead-they bend if you look at them funny!
