Closed Thread
Old 03-16-2010, 11:43 PM   #1026
shortbed70
shortbed70's Avatar
Re: What did you do to your truck today?
Originally Posted by sams60gmc View Post
We'll I haven't been on here for a while but I'm glad to see this thread still going strong!!! 1000 replies, woot. Anyways. I've gotten quite a bit done, I've machined some 8 1/2'' tubing and capped one end and cut out my control arms and welded them in. I also re built my upper bag plates out of thicker material. They turned out great. I have my bags somewhat plumbed up. They go to a T in the front bumper with a schraeder valve for now for I can just manually fill them until I get a compressor and a tank. Anyways here are the pics.
I just did the same thing with my lowers for alot less then tubular ones and I did it myself.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline
Old 03-16-2010, 11:59 PM   #1027
daverod
SSN 706
daverod's Avatar
Originally Posted by burbguy View Post
I cut off my bumpstops sunday, and after having it fall off of the floor jack(and onto me) I went to the E.R. for xrays...no broken bones.And a word of advise throw away the cheap floor jack from kragen's...LOL
Jackstands come in handy and they are cheap. HaborfreightCheap in price not quality.
daverod is offline
Old 03-17-2010, 12:03 AM   #1028
daverod
SSN 706
daverod's Avatar
The ones made out of a tube actually look like less work and less metal.
daverod is offline
Old 03-17-2010, 12:07 AM   #1029
shortbed70
shortbed70's Avatar
I dont care for the cheap ones I had my dodge truck fall on me and the rear end u bolt missed my head by about 2" and the running board hit my across the chest and leg and knocked the wind out of me and gave me a nice slash. I had the wheels blocked and the back wheels off and stands under the frame when I heard a pop and moved just enough to watch the stand fold and cheat death. One of the gussets welds broke inside the leg and caused it to fold. Glad to see you made it out ok.
Troy
Big Red Dog build
Old 03-17-2010, 12:11 AM   #1030
shortbed70
shortbed70's Avatar
I had the metal laying around and I cant afford the full tubular arms.
Troy
Big Red Dog build
Old 03-17-2010, 12:18 AM   #1031
daverod
SSN 706
daverod's Avatar
His are stock arms also. He just made his pockets out of a tube.
daverod is offline
Old 03-17-2010, 10:16 AM   #1032
sshockr
New Plugs and wires, mounted the trans crossmember, ran fuel lines to front of bed for temporary use of caprice gas tank and figured out the last piece of my header clearance issues.
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already.
1995 Impala SS - LT1/T56 Combo. This is my 1st priority project.
sshockr is offline
Old 03-17-2010, 10:38 AM   #1033
burbguy
burbguy's Avatar
yeah actually I had just pulled out the jackstands, and was laying on the driveway reaching under to bleed off the "cheapy" floorjack, when the wheel of the jack got into the crack of the driveway. It then gave a little jerk and slid off of the jack and the bumper came down on my left arm. If I had a decent jack with a larger cup it probably would have stay'd, but the cup on my jack is only like maybe 2" in diameter, so it wouldn't take much to fall off... anyways I got lucky that when it came down on me it kinda spit me out instead of sitting down on me fully...
burbguy is offline
Old 03-17-2010, 11:09 AM   #1034
Chevy Fleetside
Chevy Fleetside's Avatar
I think I have that jack from Kragen you are talking about. I think the cup was about 4" round. Well on my other jack that I didn't like, had about a 7" round cup so I used that one instead. I also have the 6 ton jack stands from Harbor Fright (no that is not a typo ) and seem to be doing fine.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 03-17-2010, 05:41 PM   #1035
kizer
Its Deja Vu time again
kizer's Avatar
Finally got the stock steering wheel off and the shaft out of the column. Now I'm close to pulling the cab and not worrying about stabbing the ground when I put it on stands.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline
Old 03-17-2010, 06:16 PM   #1036
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Have all the drive shafts back today. Primed ready for paint when we spray the frame and 17" steel wheels.
aerotruk63 is offline
Old 03-17-2010, 08:38 PM   #1037
Rob H.
Rob H.'s Avatar
I put the good driver's side sunvisor on that I got off of a 68 C/60 former garbage truck. I was really happy when I looked at the old truck down at Dad's and saw it had the same color visors as my 67, also got a nice vinyl covered door panel that matches mine! It had the bigger armrest instead of the small ones on my 67 but I guess you can't have everthing for free!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 03-17-2010, 09:02 PM   #1038
hb32
hb32's Avatar
I took the truck to Midas where they finished off my dual exhaust.
hb32 is offline
Old 03-17-2010, 09:56 PM   #1039
markeb01
Senior Enthusiast
markeb01's Avatar
Unfortunately it's marked as a private video and won't allow it to play.
markeb01 is offline
Old 03-17-2010, 11:09 PM   #1040
steveb64
steveb64's Avatar
Installed my modular drop spindles and checked my front tire clearance.
steveb64 is offline
Old 03-18-2010, 12:14 AM   #1041
hb32
hb32's Avatar
Fixed it.
hb32 is offline
Old 03-18-2010, 12:51 AM   #1042
markeb01
Senior Enthusiast
markeb01's Avatar
Excellent. Thanks for sharing, it sounds great.
markeb01 is offline
Old 03-18-2010, 01:44 AM   #1043
Bugeyev8
Bugeyev8's Avatar
Originally Posted by hb32 View Post
Fixed it.
sounds great, is that the 292 in there??
Bugeyev8 is offline
Old 03-18-2010, 10:44 AM   #1044
Bazooka
Keepin it old school
Bazooka's Avatar
Got the gauge panel ready..
Bazooka is offline
Old 03-18-2010, 11:00 AM   #1045
onequickchevy
onequickchevy's Avatar
Drove mine. In fact i've driven it everyday this week. Nothing like having two downed vehicles at the moment. Not suffering too bad, actually loving everything but the fuel milage!
Slowly but surely getting it done.
onequickchevy is offline
Old 03-18-2010, 11:35 AM   #1046
Bugeyev8
Bugeyev8's Avatar
I like those gauges, wish I had gone that route..I used sport comps because at the time it was the direction the truck was headed, now I want a more vintage look, here is my gauge panel...alot like yours
Bugeyev8 is offline
Old 03-18-2010, 12:16 PM   #1047
hb32
hb32's Avatar
No it is a stock 230. Next I am in the market for a Holley 390 cfm carb and a Offenhauser single quad manifold to fix the Rochester stumble.
hb32 is offline
Old 03-18-2010, 01:31 PM   #1048
Dan in Pasadena
Dan in Pasadena's Avatar
Nice looking truck. I had a friend with one of these years ago, and finding all the pieces to make a decent grille was next to impossible. To see a chrome one in that condition is amazing. The seat looks like a great fit. I like the addition of the fog lights, they look great.
Thanks. The grill is CLOSE, but not perfect. It has a little tear and some minor rust on the top bar near the driver's side. I'm hoping a little grinding, a minor MIG repair and re-chroming (someday!) will make it right. I recently had to take part of it apart and found the price tag on it: $650 Then I went on eBay and saw one with 14 bids on it up to $800. That's REALLY crazy.
As for the fogs - I got them for $10 at an Estate Sale recently and they cleaned right up - so I HAD to try them on my truck. I haven't decided how much I like them yet. I'm fine with the truck being Old School but I'm Old Man enough all by myself! I don't need to add to it in that way.
Dan in Pasadena is offline
Old 03-18-2010, 03:42 PM   #1049
daverod
SSN 706
daverod's Avatar
I put a $10 rebuild kit in mine. Fixed the stumble. The acc. pump gets dried out and does'nt work.
daverod is offline
Old 03-18-2010, 07:38 PM   #1050
DWright
Shlong Bed Club
DWright's Avatar
i have an offy single quad intake. pm me if youre interested.
"If it ain't broke, hit it with a hammer, then fix it.."
DWright is offline
Closed Thread
