rear end width
I am trying to find out if the rear end width is the same with an 88 suburban as it is on the 87 down pu and does anyone know the gear ratio?
Member of the longbed union.
Re: rear end width
6*- early 70 is the same short rear, Late 70-87 is the wider rear. rear gears really depend on a bunch of stuff.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
Rollin' Old Skool
Re: rear end width
i think the rear end would be the same width, considering '88 Burb was still square-body...no idea what all options for gears were
60-66 Nut
Re: rear end width
![]() The width should be the same as the late '70-'87 pickups which is 63 1/2-5/8" As for gear ratio, IMO you'll just have to pull the rear cover. Some guys swear by counting pinion rotations per wheel rotation, but I don't have much luck with that one
