Old 03-17-2010, 04:27 PM   #1
clinebarger
Re: 2004 yukon xl tranny slipping
Originally Posted by neo297 View Post
In my research I saw where some companies add extra clutch plates to the 3-4 pack is this needed for a stock motor that does moderate towing occaisionaly?
Every 700R4/4L60/4L60E I build gets 9 3-4 clutches VS 6 the factory uses, I consider it mandatory, Even the V6 transmissions that have 5 from the factory.
If it happened all the sudden its probably a apply curcuit problem(cracked servo piston, busted separator plate, bad lip seals on the apply piston, ETC...)
So i whould get it rebuilt because just putting clutches in it will not solve the apply curcuit problems.
clinebarger is offline   Reply With Quote
Old 03-17-2010, 04:40 PM   #2
lyrikz
PITbut
lyrikz's Avatar
I knew they had some goodies when rebuilding. Absolutely you would want to have it gone over completely.
Hey cline, do you guys have a tranny dyno there??? Whats your average rebuild cost on his transmission??
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 03-17-2010, 04:55 PM   #3
clinebarger
I have worked in some transmission shops that do have dynos, but a 4L60E is hard to dyno without a stand alone controller that shop owners dont want to buy.
$1200 to $1500 with R&R. $800 to $1000 bench job.
Old 03-17-2010, 05:23 PM   #4
neo297
Thanks guys you have confirmed what I was thinking, there is just no sense in not putting a rebuilt in as long as the old one has to come out. I am going to make sure I have an up graded 3-4 pack do i need to ask for a 4l65e
to get the upgrade or are the rebuilt "4l60E's" already there. I know the 65's did not have 8 or 9 plates in 3-4 but had more than the 60's. I also thought the 65 had different planetery set. I am going to present these questions to my mechanic so I can ensure I get the best tranny to put in. I do appreciate the input and will post back when the repairs are done.
Paul
neo297 is offline   Reply With Quote
Old 03-17-2010, 10:24 PM   #5
clinebarger
Paul
4L65Es have 7 clutches, and have a 5 pinion planetary gear set VS 4 on 4L60Es. A quality rebuild on your 4L60E will be good.
Old 03-18-2010, 12:00 PM   #6
neo297
Thank you I had takren it in yesterday at lunch and there were no dtc codes it showed it to be shifting into third and then it just slips bad he told me it would nee dto be pulled so I told him to get me prices on a gm rebuild that has 100,000 mile /3yr warranty v. his supplier of rebuilts with a 90 day warranty and based on cost we will proceed accordingly. Thanks to all who responded.
paul
