"something witty here"
ccp tubular motor mount perches
Does anyone know if the ccp sbc tubular perches will work with a bbc? or is there another reputable company that has good quality products that I should use? Im just not sure how I feel about the factory bbc stands and really dont wanna pay 250 for a set + motor mounts...
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
![]() Join Date: Aug 2004
Re: ccp tubular motor mount perches
I have a set of those exact ones, the gray powder coated ones, couldnt use them cuz I wanted to set the engine back to the rear mount, I used POL perches, still use the pin type motor mount. I am not sure if a pin type motor mount will work on a BB. If you interested in these, PM me, will make you a good deal.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
so these would work with the front holes on the engine crossmember? how tight is the fit between the firewall and dizzy using the rear holes?
