Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-17-2010, 11:10 AM   #1
djracer
djracer's Avatar
15x14 Wheel with trailing arms
Do you guys think it would be a problem to run a 15x14 wheel with only 3.5 inches of back spacing with stock trailing arms? I know the rear would have to be narrowed.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-17-2010, 09:16 PM   #2
57sailplane
57sailplane's Avatar
Re: 15x14 Wheel with trailing arms
i would really like to know how wide will fit also.
by the way dj if yo dont mind me asking can you remember what was under your truck width wise when it was a stepside. this is what i am needing. i know they are differant.
later andrew K
57sailplane is offline   Reply With Quote
Old 03-17-2010, 09:39 PM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
what I can tell you is that 15x13 will fit on a stock axle but I had my stock rallies cut and wided (6 lug) it was alot cheaper than buying a custom wheel or clipping an axle
if your woundering why 13" well its half way between the two PS tires availabe in a 30" tall tire so it give me options on width
I have een woundering how you get that thing to stick...
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-17-2010, 10:35 PM   #4
djracer
djracer's Avatar
Tom ran a 12 inch wheel on the truck but I don't know what backspacing. The rear has been narrowed an inch or two on each side. I know where I can get a smokin deal on a set of wheels but I'm not sure if the backspacing will work with trailing arms and I'm not taking them off.
Hottrucks look and see how far it is from the back of your wheel to the trailing arms please.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-18-2010, 06:59 AM   #5
Hottrucks
Hottrucks's Avatar
my stock 8" rally has 8 1/2" left before it hits the TA but I have bags and they are about an inch closer to the rim...I guess I could swtich to coil overs If I needed more room
Jeff
Old 03-18-2010, 07:36 AM   #6
djracer
djracer's Avatar
This truck will have coilovers so they should work. Now all I need is some money.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-18-2010, 08:00 AM   #7
Hottrucks
Hottrucks's Avatar
kevin keep in mind that I have a lead on cutting and widening our stock wheels for cheap to any specs we need...I'm waiting for mine to get back to me before I say anything about it..I want to see the work they do, if it good I hope that we can bury the guy in a few sets for us guys who want wider wheels and tires but dont have a big budget or just want that stock look without calling one of those fancy wheel companies and paying big $$$ for a rim
Jeff
Old 03-18-2010, 08:56 AM   #8
djracer
djracer's Avatar
That is a thought. Let me know how the turn out.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-18-2010, 09:31 AM   #9
rockvette
rockvette's Avatar
Cool Re: 15x14 Wheel with trailing arms
Hey guy I am running 17x12 with a 9" back space. Check out my site for pictures http://photobucket.com/rogers-64 also under albums click Ineeda for more pictures
1972 corvette (454-4speed)
1960 corvette (283-2-4barrel-powerglide)
1966 corvette (427-4speed)
1964 chevrolet stepside (502-6speed)
2002 corvette (LS2-6speed)
rockvette is offline   Reply With Quote
