Old 03-18-2010, 03:59 PM   #1
Renfro85
Spark plug blew out the hole!!!
so i had new exhaust installed on the truck today with a 1 in 1 out magnaflow, i made it about 6 miles down the road and then the number 1 spark plug went pop. im curious if the new amount of backpressure the truck has caused this or if it was just a freak coincidence. Btw its a inline 250 motor if that helps any
Renfro85 is offline   Reply With Quote
Old 03-18-2010, 04:17 PM   #2
Arizona oldguy
Arizona oldguy's Avatar
Re: Spark plug blew out the hole!!!
It seems like this is an odd coincidence, the exhaust would only create pressure during the exhaust stroke and the exhaust valve would be open. The highest pressure would be during the compression stroke. I have a sneaky feeling that your plug hole was in bad shape, if the plug will not tighten up you made need to do a Heli-coil thread replacement. Most good auto part stores will have them. Good luck and God bless
Arizona oldguy is offline   Reply With Quote
Old 03-18-2010, 04:19 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Or the plug was loose to begin with...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-18-2010, 04:31 PM   #4
Renfro85
well i did just replace the plugs last monday lol, maybe i over tightened or not enough, guess well see with the new plug
Old 03-18-2010, 04:38 PM   #5
Leviticus
Shake and Bake!
Leviticus's Avatar
Man that sucks, like Arizona said you can usually get lucky and do a heli-coil but hopefully it didn't take all of the threads with it on the way out.
I had a Ferd V10 back in the day that was known for doing that but I was lucky it never happened to me before I sold it. Heard some horror stories of guys having to replace multiple sets of heads though.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 03-18-2010, 04:41 PM   #6
Renfro85
well the whole plug didnt blow just the white part, the rest is still threaded in the head, so im lucky i can get it out with a socket
Old 03-18-2010, 04:46 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Possibly it was bumped during the exhaust install and blew out.Or maybe it was just a factory "bad plug".Glad to hear it was an easy fix.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-18-2010, 04:50 PM   #8
Leviticus
Shake and Bake!
Leviticus's Avatar
Oh, you're Golden then. Just pop it out and get some good quality pugs (Not sure what you were running before) and pop em in. Like panel said, if it got bumped and cracked it will blow out.
Thomas Jefferson
Old 03-18-2010, 04:56 PM   #9
GASoline71
GASoline71's Avatar
It prolly didn't "blow out"... it "broke off".
Gary
Old 03-18-2010, 05:25 PM   #10
Arizona oldguy
Lots of good advice goin on here. Check your plug socket, it needs to have a rubber insert, it will help you not break plugs when you are putting the El Paso cinch on em.
Old 03-18-2010, 07:15 PM   #11
Leviticus
Shake and Bake!
Leviticus's Avatar
Gary
I think "Blow Out" sounds cooler
Thomas Jefferson
Old 03-18-2010, 07:44 PM   #12
gkesseru
gkesseru's Avatar
The only time I've seen this was with a cracked head. Coolant gets into the Cylinder and cannot be compressed. The term to cover is is "Oh you've hydraulic-ed your plugs."
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 03-18-2010, 08:02 PM   #13
mbgmike
We were at an All Harley Drag race about 10 or twelve years ago in Temple Texas. Joey Mancuso blew a plug out, It hit a tree limb about 3 inches in diameter above the stands and it fell into the stands right where no one was sitting and it was pretty crowded. It scared a bunch of people though
mbgmike is offline   Reply With Quote
Old 03-18-2010, 10:12 PM   #14
Renfro85
i was using ac delco plugs, i put a new one in and so far so good. only bad thing about it, is i think some of the plug might have made its way through the radiator
Old 03-19-2010, 10:19 AM   #15
RustyBucket
RustyBucket's Avatar
about 7-8yrs. ago a kid in my Son's band had a crappy little Furd Aerostar that blew the center white porcelain part of a plug out of the metal plug body. The base of the plug was still screwed in the head and the white part was in the wire boot hanging on the wire. Replaced it with a new plug and away he went. Think it was an Autolite------- my Son still has it. Never seen one do that in 50+ years.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 03-19-2010, 03:30 PM   #16
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
prolly happened when you were torquing the plug, if you don't keep the socket centered then they will crack. I've done this a few times....and it was always after the parts store closed so I had to wait till the next day or put an old plug back in.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-19-2010, 03:44 PM   #17
LONGHAIR
I have seen them blow-out before, but it was on a blown street rod. The white insulator is just crimped intop the top of the metal fitting.
I have even seen them un-screw and pop the entire plug out, but that was on a I6 Furd. Makes a horrible racket doesn't it?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-19-2010, 05:24 PM   #18
Renfro85
the noise was embarrassing to say the least, but yea all that was left of the plug was the threaded part.
