Old 05-10-2003, 03:18 PM   #1
CustomChevy
if you're sticking with the bench seat, i would either stick with the column shift or go with a Lokar shifter. SHould be able to work fine with a bench seat. Of course, if you go with the floor shifter, you're gonna have to get another column or let the empty slot on the column stare back at you.
In either case, good luck!!
CustomChevy is offline   Reply With Quote
