Old 03-19-2010, 01:19 PM   #1
longboard
How to store your truck
Hello all!
I love the site, this is my first post and I'm hoping you all can help me.
I have a 1971 C10 (350) and won't be driving it for 6 months, possibly longer. I will store it in a garage but what things do I need to do to prepare it for some long-term storage?
Do I put it up on blocks?
Drain the fuel, oil, trans. fluid?
Disconnect the battery?
If someone had a good checklist of storage tips, that would be great.
Thanks so much everyone and I appreciate the great site.
longboard is offline   Reply With Quote
Old 03-19-2010, 02:18 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: How to store your truck
Get the gas out of the tank and run the engine until the carb is dry. Modern gas is hell on carburetors when it sits for any real length of time. Barring that, try to use a fuel stabilizer of some sort.
Disconnect battery.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-19-2010, 02:25 PM   #3
longboard
Thank you so much TX Firefighter. I'm new to being a classic truck owner and not all that familiar with many things involving repair and maintenance. So I have a question about your reply;
If I get the gas out of the tanks (I have 2) why would I need a fuel stabilizer?
I'm sure I'm missing something simple here, but thanks.
Old 03-19-2010, 02:36 PM   #4
Tx Firefighter
I guess my response is kind of confusing. I meant to say, get the gas out of the truck if you can. If you can't or don't want to (mobility of vehicle in an emergency for instance), just pour in some fuel stabilizer to the gas tank and run the truck to get it up into the carb.
Old 03-19-2010, 02:41 PM   #5
longboard
Thank you, I get it.
Would you put it up on blocks to preserve the tires better?
Old 03-19-2010, 03:13 PM   #6
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Couldn't hurt, it'll keep the tires from going square on you.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-19-2010, 04:03 PM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Uphere in the cold north we regularly store our vehicles 6 or 7 months a year every year. I've been storing vehicles since the early 80's and all I've ever done is add fuel stabilizer and yank the battery for the Winter.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 03-19-2010, 04:34 PM   #8
longboard
Thanks guys, I really appreciate all the help.
If any other storage tips come up, let me know.
Old 03-19-2010, 06:29 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Might want to put some mothballs,dryer sheets or whatever other rodent deterent in/around it.If the paint is nice wash it well and wax it.Even though it will be in a garage it never hurts to protect your paint.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-19-2010, 09:31 PM   #10
longboard
great tip, thanks much!
Old 03-19-2010, 09:38 PM   #11
hayhauler71
hayhauler71's Avatar
Change the oil, old oil will contain acids and likes to do some pitting on your engine bearings.
hayhauler71 is offline   Reply With Quote
Old 03-20-2010, 09:57 AM   #12
longboard
Is there a danger to simply draining the old oil and NOT replacing it? Or is it best to store a truck full of new oil?
Thanks.
Old 03-20-2010, 01:26 PM   #13
hayhauler71
change it and only run it for a few seconds to get fresh oil to the bearings
Old 03-21-2010, 03:24 AM   #14
Jacfourteen
Thanks.
Yeah, if you forget that you drained the oil and start it that is a real danger to your engine . I know it sounds dumb that you would forget something like this, but I've done it before. Once after I got done swapping an engine I went through my checklist of everything hooked up and all that. Then I started it up, luckily I forgot to plug in the MAF sensor so it died after running about 5 seconds, then I thought oh s### I forgot to put in oil! I filled it up with oil, plugged in the maf and it was all good.
Old 03-21-2010, 08:39 AM   #15
longboard
good advice, thanks.
storage, storing
