Old 03-21-2010, 01:24 PM   #1
clayton1967
clayton1967's Avatar
early classic 4/6 drop kit
Hey just wondering a few thing about this drop kit if anyone could help?
1. Hows the ride?
2. do i need to c-noth the frame?
3. What wheel sizes are people running?
4. was the install easy? (seems easy)
5. did you like the kit?
thanks a lot really wanna go lower then what i have now which is 2/4 just wondering what people thought?
Thanks for the help!
clayton1967 is offline   Reply With Quote
Old 03-21-2010, 01:33 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: early classic 4/6 drop kit
There are several running that drop right now. To me it's the perfect classic drop. 72BlackBeauty's truck is a great example...hopefully he'll post it up with sizes. Some run a C-notch if they plan on having loads in their bed but it's not required. You can run factory height wheels or 20's with the same overall height as factory (or anything in between) Hopefully others will chime in.
Old 03-21-2010, 01:59 PM   #3
Mondo
Mondo's Avatar
The ride is great, though you can't carry a lot of weight in the bed as the rear springs are softer for a better ride.
Going any lower and you'll probably have to C notch the rear and it gets a little more complicated in the front (camber issues etc..).
Mondo is offline   Reply With Quote
Old 03-21-2010, 02:33 PM   #4
powell72
powell72's Avatar
In order-
1. Great
2. No
3. 15x6.5'' and 15x8'' on 245/60 and 275/60/15's
4. Yes, except for removing the rivets for the upper shock mounts
5. Yes, Excellent quality product.
Definitely go for the 4/6.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 03-21-2010, 02:49 PM   #5
Fitz
Early Classic is a top notch outfit. If you have a problem or there's something you don't understand call Stan and he will help. If something isn't right, just call and they do not hesitate to replace a part.
Their drop kit is also top notch!
Fitz is offline   Reply With Quote
Old 03-21-2010, 03:09 PM   #6
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I just placed an order withthem last week for a kit, and it arrived with small block springs instead of BB. One of the reasons I went with ECE was because everyoone here speaks so highly of their customer service, and now I too can say the same. Picked up the phone, didn't have to do the "press 1 for English", or listen to elevator music for an hour like other places.
No hassle, replacement on the way. Great people.
Zoomin is offline   Reply With Quote
Old 03-21-2010, 03:11 PM   #7
clayton1967
thanks for the help guys
Old 03-21-2010, 04:14 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Read 72BlckButy's project Blank Slate thread. He has the install info here:
http://67-72chevytrucks.com/vboard/s...d.php?t=353633
Keith
Convert to disc brakes.
Old 03-21-2010, 04:21 PM   #9
John Fabris
TOTY 2006
John Fabris's Avatar
I have that kit on my 67. I like the stance, running 265/60/15 on 15x8 wheels.
Pretty easy kit with some minor work needed to remove old shock hangers (rivits).
I did not use a cnotch.
In my opinion, as I drive this truck more and more, I feel the front is too low for most bad roads around the bay area. I do bottom out every now and then on the inner ends of the lower a-arms. So, while it looks good, I would run the 3/5 drop for daily driver unless your roads are in very good shape.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 03-21-2010, 04:28 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
As many have already said, this is the kit to buy. All the parts are included and it goes together like pie.
No c-notch is required, unless, you will haul fairly heavy loads; I have yet to bottom out (except once) during normal driving conditions.
EDIT...
As far as the ride quality, I would recommend it to anyone. Smooth and clean, not rough even with the roads in Missouri.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-21-2010, 11:27 PM   #11
clayton1967
thanks guys for all the help! i am gonna go with the 4/6 even the the roads in spokane, wa are horrible its not my daily driver! i'll be sure to post the progress! thanks again!
Old 03-21-2010, 11:47 PM   #12
AusTx68
AusTx68's Avatar
I'm glad I saw this post. I have the ECE 4/6 drop. The front is higher than I expected but figured it needed to settle. After reading your post I realized that I order the kit when I had a big block. I changed to a small block since installing the kit. Guess I'll be buying new springs!
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 03-22-2010, 12:35 AM   #13
VA72C10
VA72C10
VA72C10's Avatar
you could always just cut one coil out of it but it is probably best for the best handling to get the proper spring.
Old 03-22-2010, 01:22 AM   #14
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
ttt
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-22-2010, 10:34 AM   #15
NicoSlam
I recently did the 4/6 ECE on my 69SWB. I have 30" tires (29.25" diameter) and I love the "full" look. 15x7 in the front and 15x8 rear. I will probably go with 338's when I'm done installing the A833 4 speed OD tranny. The bottom pic shows the truck before the drop.
NicoSlam is offline   Reply With Quote
Old 03-22-2010, 12:28 PM   #16
1970SWB
1970SWB's Avatar
I am planning on going with the 4/6 drop as I build my 70swb, I'm also converting to 5-lug using front suspension from an '85 chevy pu. my question is do you have to cut/notch the lower control arms to run 15" wheels, because of the dropped spindles. I'm thinking of the 15X7 ralleys for the front & 15X8 rallys on the rear.
1970SWB is offline   Reply With Quote
Old 03-22-2010, 12:33 PM   #17
816allen
816allen's Avatar
That looks great thats what i want!
96 Burban Sold
99 Z71 Sold
65 C10 Sold
72 C10 Sold
87 Short Bed Lowered Daily Driver
http://s623.photobucket.com/albums/tt314/sswagon/
http://www.chevygmcofkc.org/forums/forum.php
816allen is offline   Reply With Quote
Old 03-22-2010, 01:05 PM   #18
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
No need to cut or notch anything. The wheels will clear fine.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-22-2010, 01:46 PM   #19
big_al_71
big_al_71's Avatar
Another one here with ECE 4/6 drop kit!!!
To answer your questions:
1. Hows the ride?
Not bad if you hit a bump hard enough you do feel it.
no
18/20 295-45-20 & 255-50-18
straight up not too bad from 1-10 I will give it a 5 with the proper lift and tools.
yes I do...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-11-2010, 04:27 PM   #20
GKsport67
GKsport67's Avatar
Nuff Said!! ECE it is...
GKsport67 is offline   Reply With Quote
Old 04-11-2010, 05:04 PM   #21
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
-Ron-
OldSkool71 is offline   Reply With Quote
Old 04-11-2010, 05:06 PM   #22
72_cheyenne
72_cheyenne's Avatar
Question Re: early classic 4/6 drop kit
will 295/40/20 - 255/40/20 tires work with this drop??
Red Chevy's
72_cheyenne is offline   Reply With Quote
Old 04-11-2010, 05:10 PM   #23
72BlckButy
Tot Roddin'
72BlckButy's Avatar
72 cheyenne.. here's your answer: yes.
Check out my build thread for more info...
-Nate
Old 04-11-2010, 05:17 PM   #24
72_cheyenne
Thanks 72BlckButy...nice truck!
Red Chevy's
Old 04-11-2010, 05:26 PM   #25
Curbstone Mech
Active Member
I replaced my eCE 2/4 drop with 4/6, but I believe it was actually a 3 1/2- 6 drop, 2 1/2 in drop spindles with a 1 in drop spring all from ece. I had to cut the rubber bump stops by 1 inch. It is exactly the look I wanted.
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
