early classic 4/6 drop kit
Hey just wondering a few thing about this drop kit if anyone could help?
1. Hows the ride? 2. do i need to c-noth the frame? 3. What wheel sizes are people running? 4. was the install easy? (seems easy) 5. did you like the kit? thanks a lot really wanna go lower then what i have now which is 2/4 just wondering what people thought? Thanks for the help! ![]() |
VA72C10
![]() Join Date: Mar 2008
Re: early classic 4/6 drop kit
There are several running that drop right now. To me it's the perfect classic drop. 72BlackBeauty's truck is a great example...hopefully he'll post it up with sizes. Some run a C-notch if they plan on having loads in their bed but it's not required. You can run factory height wheels or 20's with the same overall height as factory (or anything in between) Hopefully others will chime in.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
The ride is great, though you can't carry a lot of weight in the bed as the rear springs are softer for a better ride.
Going any lower and you'll probably have to C notch the rear and it gets a little more complicated in the front (camber issues etc..). Last edited by Mondo; 03-21-2010 at 02:01 PM. |
In order-
1. Great 2. No 3. 15x6.5'' and 15x8'' on 245/60 and 275/60/15's 4. Yes, except for removing the rivets for the upper shock mounts 5. Yes, Excellent quality product. Definitely go for the 4/6. ![]()
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 03-21-2010 at 05:11 PM. |
Early Classic is a top notch outfit. If you have a problem or there's something you don't understand call Stan and he will help. If something isn't right, just call and they do not hesitate to replace a part.
Their drop kit is also top notch! |
Man of Mini-Talents
I just placed an order withthem last week for a kit, and it arrived with small block springs instead of BB. One of the reasons I went with ECE was because everyoone here speaks so highly of their customer service, and now I too can say the same. Picked up the phone, didn't have to do the "press 1 for English", or listen to elevator music for an hour like other places.
No hassle, replacement on the way. Great people. |
thanks for the help guys
67-72 parts collector,…
![]() Join Date: Nov 2002
Read 72BlckButy's project Blank Slate thread. He has the install info here:
http://67-72chevytrucks.com/vboard/s...d.php?t=353633
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-21-2010 at 11:45 PM. |
TOTY 2006
![]() Join Date: Dec 1999
I have that kit on my 67. I like the stance, running 265/60/15 on 15x8 wheels.
Pretty easy kit with some minor work needed to remove old shock hangers (rivits). I did not use a cnotch. In my opinion, as I drive this truck more and more, I feel the front is too low for most bad roads around the bay area. I do bottom out every now and then on the inner ends of the lower a-arms. So, while it looks good, I would run the 3/5 drop for daily driver unless your roads are in very good shape. |
Tot Roddin'
As many have already said, this is the kit to buy. All the parts are included and it goes together like pie.
![]() No c-notch is required, unless, you will haul fairly heavy loads; I have yet to bottom out (except once) during normal driving conditions. EDIT... As far as the ride quality, I would recommend it to anyone. Smooth and clean, not rough even with the roads in Missouri.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 03-21-2010 at 04:50 PM. |
thanks guys for all the help! i am gonna go with the 4/6 even the the roads in spokane, wa are horrible its not my daily driver! i'll be sure to post the progress! thanks again!
#12 | |
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
VA72C10
you could always just cut one coil out of it but it is probably best for the best handling to get the proper spring.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
ttt
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#15 |
![]() Join Date: Nov 2009
I recently did the 4/6 ECE on my 69SWB. I have 30" tires (29.25" diameter) and I love the "full" look. 15x7 in the front and 15x8 rear. I will probably go with 338's when I'm done installing the A833 4 speed OD tranny. The bottom pic shows the truck before the drop.
#16 |
I am planning on going with the 4/6 drop as I build my 70swb, I'm also converting to 5-lug using front suspension from an '85 chevy pu. my question is do you have to cut/notch the lower control arms to run 15" wheels, because of the dropped spindles. I'm thinking of the 15X7 ralleys for the front & 15X8 rallys on the rear.
#17 |
That looks great thats what i want!
96 Burban Sold 99 Z71 Sold 65 C10 Sold 72 C10 Sold 87 Short Bed Lowered Daily Driver ![]() http://s623.photobucket.com/albums/tt314/sswagon/ http://www.chevygmcofkc.org/forums/forum.php |
#18 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
#19 |
Another one here with ECE 4/6 drop kit!!!
To answer your questions: 1. Hows the ride? Not bad if you hit a bump hard enough you do feel it. 2. do i need to c-noth the frame? no 3. What wheel sizes are people running? 18/20 295-45-20 & 255-50-18 4. was the install easy? (seems easy) straight up not too bad from 1-10 I will give it a 5 with the proper lift and tools. 5. did you like the kit? yes I do...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 03-22-2010 at 02:55 PM. |
#20 |
Nuff Said!! ECE it is...
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 |
#21 |
C/10 CLUB MEMBER
![]() Join Date: Jul 2003
-Ron- ![]() Last edited by OldSkool71; 04-11-2010 at 06:47 PM. |
#22 |
will 295/40/20 - 255/40/20 tires work with this drop??
Red Chevy's ![]() |
#23 |
Tot Roddin'
72 cheyenne.. here's your answer: yes.
![]() Check out my build thread for more info...
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#24 |
Thanks 72BlckButy...nice truck!
Red Chevy's ![]() |
#25 |
Active Member
![]() Join Date: Feb 2000
I replaced my eCE 2/4 drop with 4/6, but I believe it was actually a 3 1/2- 6 drop, 2 1/2 in drop spindles with a 1 in drop spring all from ece. I had to cut the rubber bump stops by 1 inch. It is exactly the look I wanted.
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi Last edited by Curbstone Mech; 04-11-2010 at 05:27 PM. |
