Old 02-02-2010, 07:18 PM   #1
michael bustamante
michael bustamante's Avatar
Auto Tranny Cross-member (member? you member!)
I have 2 auto transmission crossmembers for our trucks. as you know these are needed when converting to an auto tranny. One has all 4 mount, locations and one has the upper mounts removed, (probably to run exhust )
40.00 for the one pictured and 30 for the other (with the upper mounts) both are very solid. out of NM trucks no rust!!!
plus the ride
1967custom
michael bustamante is offline   Reply With Quote
Old 02-02-2010, 09:33 PM   #2
tjsblazer
tjsblazer's Avatar
Re: Auto Tranny Cross-member (member? you member!)
A little new to this but are the cross members not the same (TH350 to SM465)? I thought they just used different tranny mounts. I am looking in to some swapping.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 02-03-2010, 03:58 PM   #3
michael bustamante
no they are different and they are in different locations on the frame. the manual tranny ones sit right behind and under the firewall while the auto tranny ones that I have sit under the cab, like under the bench seat more or less, the manual traany have a mount on either side of the tranny while the auto tranny have one mount in the center rear of the trans
1967custom
Old 02-03-2010, 06:34 PM   #4
budder71
how much shipped to 39402 ?
budder71 is offline   Reply With Quote
Old 02-03-2010, 06:58 PM   #5
michael bustamante
which one are you needing? the one in the picture or the one with the 2 additional arms rivited on. (great for trucks with alot of torque but get in the way of some custom exhaust systems) 15 dollars for the one in the pic. 22 for the other
1967custom
Old 02-03-2010, 07:26 PM   #6
budder71
I have a 68 1/2 ton 4WD Suburban that currently has a manual 4 speed transmission
in it and I will be converting it to an automatic very soon. Which ever cross member you have that will work for that application, if either one will work, I will take it so
just PM me the details if either one will work....
Old 02-03-2010, 07:33 PM   #7
michael bustamante
unless youre running a big block the one in the pic will be good, Ill pm you the info
1967custom
Old 02-04-2010, 12:50 AM   #8
teeitup
Just like to part out trucks!!
teeitup's Avatar
As far as I know, 4x4 are different than 2wds. 4 speed and automatic crossmembers are the same in 4x4's. The lower bracket on 4x4 is deeper. No difference between 2wd bb and sb.
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 02-04-2010, 11:25 AM   #9
michael bustamante
Ive never seen a 4wd tranny crossmember. yeah I guess that would be a big difference. These are from 2wd trucks. Sorry about that
1967custom
Old 02-04-2010, 06:53 PM   #10
budder71
if that is the case I don't need it then, thanks for the information teeitup !!!!!
I am a bit green at the mechanics of the manual to auto swap but have read several
threads on the forum....
Old 02-04-2010, 06:54 PM   #11
michael bustamante
its a good thing we found that out. thanks teeitup. you saved me some embarressment
1967custom
Old 02-04-2010, 11:21 PM   #12
teeitup
teeitup's Avatar
No problem guys, just glad to help out. Randy
1980 chevy swb 4x4
Old 02-07-2010, 09:15 AM   #13
Tod Maznec
I need help men:
I want to use an new aluminum Bell housing without the lower mount bolts in my 71 C10 Shortbed 3 speed /350ci. My truck frame has no provision right now for a mount to the tail of the transmission. Originally it had a steel bell with 2 tapped mount flanges up front and only rear support from the center carrier bearing of the 2 pc drive shaft.
Can I use one of these?
Parts?
Tod Maznec is offline   Reply With Quote
Old 02-08-2010, 01:28 PM   #14
michael bustamante
no I dont think this would work for you, if you fab it to mount the rear of the manual tranny I would think that you angle would be all wrong. sorry man, now if youre converting to a auto tranny than this is whatg you need but you will have to remove the manual tranny crossmember
1967custom
Old 02-10-2010, 04:46 PM   #15
70BLAZERX2
I have a 454 with a muncie 4speed in my 70 2wd blazer with a 2wd auto crossmember...No mods at all...If your 3 speed has a trans mount location...some do..it will work..I have done that before
Originally Posted by Tod Maznec View Post
I need help men:
70BLAZERX2 is offline   Reply With Quote
Old 02-10-2010, 07:16 PM   #16
michael bustamante
if your 3 speed has that mount that hes talking about, let me know and ill set you up
1967custom
Old 02-17-2010, 02:12 PM   #17
Baby John
I know this is an old post but I sure do need a transmission cross member. I have no idea really what I need. I have a 72 stepside GMC that originally had a straight six in it with a 3 speed manual transmission...column shift. The PO converted to a Turbo 350 Auto Transmission (I think...) and used some ugly half assed crossmember that barely spans the width of the frame. I would like a nice clean crossmember.
So would one of your crossmembers work for my application? If so shipping to 39114? And lastly, I'm financially embarrassed right now and have commitments for my only spare $100.00 for a bumper I'm buying next weekend. If this will work could you possibly wait a couple weeks till March 5?
Baby John & Tyler Shows
My son and I are resto-rodding a '72 GMC Stepside
Baby John is offline   Reply With Quote
Old 02-17-2010, 03:09 PM   #18
michael bustamante
if your truck is a 2wd it is the one you need, (factory) your frame will have the bolt holes already, pm me and Ill give you my pay pal or my address.
Thanks man!! oh and march is fine, Ill ship it out as soon as I hear from you, 50.00 shipped, better yet, 45.00
1967custom
Old 02-17-2010, 03:52 PM   #19
Baby John
Thanks...done deal then. Let me buy the bumper next weekend, and then I'll get with you on your address and I'll mail you a check. I had a pay pal account a long time ago but I've changed companies, and email addresses since then and I basically just haven't gone through the trouble of setting up another account.
Old 02-17-2010, 04:07 PM   #20
CG
BlahBlahBlah
Title to this thread cracked me up...I member=)
Old 02-17-2010, 05:53 PM   #21
michael bustamante
boy I hope youre not the only one that got that!! I like watching the new George Lopez nite show
1967custom
Old 02-17-2010, 09:13 PM   #22
CG
BlahBlahBlah
I went to post a youtube of it in my thread, but there was some mild cursing in there. We try to keep it family friendly round here...I havent seen his show, I just hear him on my sirius radio in my car.
Ok, back to the regularly scheduled truck thread lol
Old 02-18-2010, 11:24 AM   #23
Tod Maznec
I am the guy with the 3 speed Saginaw tranny that I need to incorporate a rear tail housing transmission mount. I changed the stock steel bell housing over to an 11" alum, but the alum has no bolt up provision in the bottom of it like the stock had.
My tranny has a two hole threaded mount pad on the bttm of the rear of the tail housing under the local where the drive shaft yoke slides in.
I am considering buying a universal cross member from ClassicParts for a 50's era Chev Trucks because it is only 50$. I could then cut/weld/mod to make it fit.
Parts?
Old 02-18-2010, 01:07 PM   #24
michael bustamante
I thought the 50`s era trucks frame rails were spaced closer together than our trucks, Well if you decide you want to try a stock, mine does have the 2 hole mount provision. My 4 bolt crossmember has been spoken for but I still have the 8 bolt crossmember. it would be 67.00 shipped
1967custom
Old 03-21-2010, 03:13 PM   #25
clos69
Its Topless Season!!!!
clos69's Avatar
PM sent
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
